Mesh on front grill
Guest redberet2252
Guest redberet2252
Hi Guys, Looking for someone in scotland that can fit the mesh on to the front grills, anyone help. Now added some pics of my new baby
David
Guest redberet2252
Hi, nice looking supra you have there.
Where abouts in tayside are you?
Here is a link to a step by step mesh fitting guide:
http://www.mkivsupra.net/vbb/showthread.php?t=40235
Might be worth a read to see if you fancy having ago youself.
Hi In Dundee, seems a bit fiddly fixing the mesh, maybe try and get someone to do it
David
Guest redberet2252
Ive never fitted mesh before and i did mine last week with ease. Its very straight forward mate
Hi Did you fit it with the bumper on, was it easy and of course hows it done then
D
Ways of fixing mesh to front grill, take off bumper;) measure the approximate size of aperture, and cut out your mesh approximately 2-3 inches bigger than that, depending on the mesh type, hold in place and mould/bend it around the edge, providing you have an edge, if some bit are flat then its a bit harder to get it in place, if you want it to be permanent then you can just use fibreglass Bridger paste and apply it at strategic places around the edge, so as it squeezes through the mesh onto the fibreglass/plastic of the bumper, having cleaned the area before you started;)
If you want to be able to remove it the i find the best thing to use is some stainless steel wire bonded around the edge of the aperture,with the bridger, which you can then lace into the mesh to hold it, some people use cable ties also.
