8800 Posted April 5, 2008 Share Posted April 5, 2008 I took off the passenger door card to install the wing mirror, when i tried to pulling cable off the window switch I accidently pulled it apart. now I cant get the window rise, even from the driver side switch, could that be the fuse? if so, where can I find it? also, does the folding mirrors has their own fuses? the passenger side cant fold back but the adjustment is working ok, the driver's side is working fine, any ideas? thanks in advance for any help Link to comment Share on other sites More sharing options...
supra steveo Posted April 5, 2008 Share Posted April 5, 2008 you have made sure the window lock on the drivers side isnt on other than that have a look in the drivers kickwell and you will find the fuse box or under the bonnet Link to comment Share on other sites More sharing options...
8800 Posted April 5, 2008 Author Share Posted April 5, 2008 i checked the window lock, it wasnt it. I'll have a look in the drivers kickwell. just want to make sure in looking at the rgiht diretion, even the passenger side window switch is broken I still can use the switch on the driver side to control the window, yes? so if both switches cant lift up the window it has to be something else other than the switch? Link to comment Share on other sites More sharing options...
supra steveo Posted April 5, 2008 Share Posted April 5, 2008 check to make sure the window clip has gone all the way in Link to comment Share on other sites More sharing options...
