Fuel mix to run at 10 of the best
Alex
Can we use this stuff?
http://www.76lubricants.co.uk
Go into Products - Racing Fuel - Read it then Click on next and you'll get to the good page!!
118 Octane fuel!!! (122 European Rating whatever that it)
Ron 120+ MON 114+
But its leaded...so can we use it on a decatted car? I know lead would kill a Cat.
The rules of 10 of the Best state that any fuel and or additives can be used. :D
The car just has to be road legal...damn no slicks :sly: :D
I think I heard somewhere that leaded fuel will knacker O2 sensors . . but a new O2 sensor is only about £60, and you're not gonna be doing many miles anyway are you? :D
I can't help thinking that even with racing fuel you're not going to get something for nothing - ie even if the octane rating is really high, and you advance the ignition massively and make loads of power, won't thermodynamics or something catch up with you at some point? ie more energy being created, which needs to be dissipated by the cooling system, and withstood by the moving parts.
I was assuming mapping would stay the same and the octane used as insurance against det on the day. For sure, adding adavance to take advantage of the octane will help mid range, but then it will come back, eventually, to the point where the safety margin is once again compromised.
Can I use a mix of Optimax and Race Gas? As obviously I can't just swap the tank out for a clean one!
Chris, have an O2 sensor ready! :)
I'm not changing the map and I don't know how to advance the timing on a Supra...isn't it automatic? Just reset the ECU and drive it round for a bit?
Guest Terry S
Alex, the 106 unleaded will be sufficient & it won't destroy your o2 sensor. I have been told that an o2 sensor can take 20hrs leaded before it's knackered from new.
With the stock ECU how can you advance the timing to take advantage of the 118 fuel?? An ITC will work to a fashion, but it's not ideal
Whoops didn't see that ... got distracted by the big no.s
Indeed that stuff would be perfect just right for my MINES ECU :D
Eeeek -
55 litre (pail) £128.08 + delivery
25 litre (pail) £63.45 + delivery
208 litre (drum) £438.28 + delivery
Well at least that includes VAT! :eek:
£130 to fill 'er up! :eek:
If an engine is set up to run 'perfectly' on... say...98RON,
wouldn't it actually run slightly worse (less efficiently) if you
then use 105/110RON ? ?
Surely if you DON'T alter the timing the much higher octane won't
match the ignition characteristics ?
I know it will prevent (delay) pinking, but won't it actually produce
LESS power unless you re-time ? ?
[or, is that exactly what you just said above, and I'm a bit DERRR ? ]
STEVE.
(:stupid: )
