superpaulwilson Posted April 3, 2008 Share Posted April 3, 2008 As above really. I've just purchased some OEM spats and they should be arriving soon. I know I need to remove the old black trim and they fix to the inner arch but how do they fix to the rear quarter? All my search efforts seem to be for aftermarket spats that require tigerseal. Cheers Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 3, 2008 Share Posted April 3, 2008 Trim tape or sikaflex (for a permanent fit). Quote Link to comment Share on other sites More sharing options...
superpaulwilson Posted April 3, 2008 Author Share Posted April 3, 2008 is there a non-permanent or semi-permanent option? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted April 3, 2008 Share Posted April 3, 2008 Double sided foamy tape Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 3, 2008 Share Posted April 3, 2008 Trim tape, although i don't know how good it is long term Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted April 3, 2008 Share Posted April 3, 2008 Oh and theres the 10mm bolt that goes underneath. You know about that don't you? Quote Link to comment Share on other sites More sharing options...
paul mac Posted April 3, 2008 Share Posted April 3, 2008 is there a non-permanent or semi-permanent option? only if you go for the "Halfords ram raid look" if you want them to look decent (and part of the car) you need them fitting properly shouldn't really be in tech as well more supra chat me thinks Quote Link to comment Share on other sites More sharing options...
superpaulwilson Posted April 3, 2008 Author Share Posted April 3, 2008 Oh and theres the 10mm bolt that goes underneath. You know about that don't you? No i don't. is there a hole there or do i need to make one? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted April 3, 2008 Share Posted April 3, 2008 No i don't. is there a hole there or do i need to make one? There should be a hole on the car yes. Are they genuine OEM spats or copies? genuine ones will have a bracket on the inside that the bolt goes through to attach to the car. If they're copies and made of fibreglass then you'll have to use something strong to fix them on like sikaflex as suggested before Quote Link to comment Share on other sites More sharing options...
hoff Posted April 3, 2008 Share Posted April 3, 2008 Trim tape, although i don't know how good it is long term How perminant is it col? I really need to do mine. I was going to use the sealent stuff but with the weather being the way it is not had a chance:( Is the tape pretty instant, bolt on, stick the tape down and drive away? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted April 3, 2008 Share Posted April 3, 2008 Heres a picture of the inside of a genuine oem spat with the bracket I'm talking about... Quote Link to comment Share on other sites More sharing options...
superpaulwilson Posted April 3, 2008 Author Share Posted April 3, 2008 There should be a hole on the car yes. Are they genuine OEM spats or copies? genuine ones will have a bracket on the inside that the bolt goes through to attach to the car. If they're copies and made of fibreglass then you'll have to use something strong to fix them on like sikaflex as suggested before Yes, they are genuine OEM spats. How easy is something like sikaflex or tigerseal to use? Will I have time to get it lined up perfectly or does it grip very quick? Quote Link to comment Share on other sites More sharing options...
superpaulwilson Posted April 3, 2008 Author Share Posted April 3, 2008 shouldn't really be in tech as well more supra chat me thinks Sorry. I'd move it but don't know how. Quote Link to comment Share on other sites More sharing options...
pete_TT Posted April 3, 2008 Share Posted April 3, 2008 Tigerseal is easy enuff to use, u'll have plenty of time to line it up as it takes a few hours to set properly. Though once it does set its not going anywhere. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 4, 2008 Share Posted April 4, 2008 i used some tape on mine and it fitted fine, just make sure both surfaces and nice and clean Quote Link to comment Share on other sites More sharing options...
Ark Posted April 4, 2008 Share Posted April 4, 2008 Real OEM spats use three screws in the wheel arch, one bolt at the bottom, and spongy trim tape round the edges. So there you go. Quote Link to comment Share on other sites More sharing options...
