How do OEM spats fit?
superpaulwilson
is there a non-permanent or semi-permanent option?
only if you go for the "Halfords ram raid look" if you want them to look decent (and part of the car) you need them fitting properly
shouldn't really be in tech as well more supra chat me thinks
No i don't. is there a hole there or do i need to make one?
There should be a hole on the car yes.
Are they genuine OEM spats or copies?
genuine ones will have a bracket on the inside that the bolt goes through to attach to the car. If they're copies and made of fibreglass then you'll have to use something strong to fix them on like sikaflex as suggested before
Trim tape, although i don't know how good it is long term
How perminant is it col? I really need to do mine. I was going to use the sealent stuff but with the weather being the way it is not had a chance:( Is the tape pretty instant, bolt on, stick the tape down and drive away?
Yes, they are genuine OEM spats. How easy is something like sikaflex or tigerseal to use? Will I have time to get it lined up perfectly or does it grip very quick?
