Guest morganl7 Posted April 1, 2008 Share Posted April 1, 2008 Hi guys, I've a crack in one of my side skirts and as it's not that big am hoping that I will be able to repair it myself. Does anyone have the names of any recommended products I could use to glue the crack together? Thanks! Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted April 1, 2008 Share Posted April 1, 2008 if its originals, you will HAVE to plastic weld the crack over, if its fibreglass, grind the crack out and build on it from there:) Link to comment Share on other sites More sharing options...
Matt H Posted April 1, 2008 Share Posted April 1, 2008 Is this NWS? crack - skirt? Link to comment Share on other sites More sharing options...
miko_supra Posted April 1, 2008 Share Posted April 1, 2008 picture would be useful Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 1, 2008 Share Posted April 1, 2008 Matt H said: Is this NWS? crack - skirt? Matt, she said crack IN her skirt!! Not up it!! Depending on how big it is you'll probably get away with a bit of body filler, rub it down & then touch up over the top of it Link to comment Share on other sites More sharing options...
mr keef Posted April 1, 2008 Share Posted April 1, 2008 i know a good filler for cracks but depends how big the crack is:sly: Link to comment Share on other sites More sharing options...
Matt H Posted April 1, 2008 Share Posted April 1, 2008 mr keef said: i know a good filler for cracks but depends how big the crack is:sly: tiny apparantly, so it will suite your filler perfectly!! Link to comment Share on other sites More sharing options...
dannysupratt Posted April 1, 2008 Share Posted April 1, 2008 Matt H said: tiny apparantly, so it will suite your filler perfectly!! haha quality remark Link to comment Share on other sites More sharing options...
merckx Posted April 1, 2008 Share Posted April 1, 2008 Drill a little hole at the ends of the crack, maybe 4 times the width of the crack. The crack will find it harder to spread when it meets a hole as the stress is reduced. Link to comment Share on other sites More sharing options...
Blackie Posted April 1, 2008 Share Posted April 1, 2008 merckx said: Drill a little hole at the ends of the crack, maybe 4 times the width of the crack. The crack will find it harder to spread when it meets a hole as the stress is reduced. Good shout Link to comment Share on other sites More sharing options...
rick001 Posted April 2, 2008 Share Posted April 2, 2008 Dr_Doom said: Matt, she said crack IN her skirt!! Not up it!! Link to comment Share on other sites More sharing options...
