Guest morganl7 Posted April 1, 2008 Share Posted April 1, 2008 Hi guys, I've a crack in one of my side skirts and as it's not that big am hoping that I will be able to repair it myself. Does anyone have the names of any recommended products I could use to glue the crack together? Thanks! Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted April 1, 2008 Share Posted April 1, 2008 if its originals, you will HAVE to plastic weld the crack over, if its fibreglass, grind the crack out and build on it from there:) Quote Link to comment Share on other sites More sharing options...
Matt H Posted April 1, 2008 Share Posted April 1, 2008 Is this NWS? crack - skirt? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 1, 2008 Share Posted April 1, 2008 picture would be useful Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 1, 2008 Share Posted April 1, 2008 Is this NWS? crack - skirt? Matt, she said crack IN her skirt!! Not up it!! Depending on how big it is you'll probably get away with a bit of body filler, rub it down & then touch up over the top of it Quote Link to comment Share on other sites More sharing options...
mr keef Posted April 1, 2008 Share Posted April 1, 2008 i know a good filler for cracks but depends how big the crack is:sly: Quote Link to comment Share on other sites More sharing options...
Matt H Posted April 1, 2008 Share Posted April 1, 2008 i know a good filler for cracks but depends how big the crack is:sly: tiny apparantly, so it will suite your filler perfectly!! Quote Link to comment Share on other sites More sharing options...
dannysupratt Posted April 1, 2008 Share Posted April 1, 2008 tiny apparantly, so it will suite your filler perfectly!! haha quality remark Quote Link to comment Share on other sites More sharing options...
merckx Posted April 1, 2008 Share Posted April 1, 2008 Drill a little hole at the ends of the crack, maybe 4 times the width of the crack. The crack will find it harder to spread when it meets a hole as the stress is reduced. Quote Link to comment Share on other sites More sharing options...
Blackie Posted April 1, 2008 Share Posted April 1, 2008 Drill a little hole at the ends of the crack, maybe 4 times the width of the crack. The crack will find it harder to spread when it meets a hole as the stress is reduced. Good shout Quote Link to comment Share on other sites More sharing options...
rick001 Posted April 2, 2008 Share Posted April 2, 2008 Matt, she said crack IN her skirt!! Not up it!! Quote Link to comment Share on other sites More sharing options...
