Alex Posted July 25, 2002 Share Posted July 25, 2002 PLease just confirm something for me... If I shut off the engine and put my hand on the rad it should be very hot all over yes? Should I in fact not really be able to just put my (girlie oversensitive hand) flat on the radiator straight after a run in the car. This is the side of the radiator nearest the fan, reaching over the shroud and through the fan. The ends are hot just not the centre....which I'm assuming is the big area which is blocked. If it is blocked are there any other really evil cleaning products out there? Can I get it it cleaned through ultrasonics if all else fails? Maybe I'll just chuck a load of Caustic Soda in it!!! Any help greatfully received. Quote Link to comment Share on other sites More sharing options...
Mark Kindell Posted July 25, 2002 Share Posted July 25, 2002 Just take out the rad and look in the yellow pages for someone who rebuilds rads. They will check it and then just put a new core in it £80-£150ish last time i had one done ! Quote Link to comment Share on other sites More sharing options...
GavinL Posted July 25, 2002 Share Posted July 25, 2002 Originally posted by Mark Kindell Just take out the rad and look in the yellow pages for someone who rebuilds rads. They will check it and then just put a new core in it £80-£150ish last time i had one done ! The MKIV doesn't use a standard core size...we have been there already Quote Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 25, 2002 Share Posted July 25, 2002 If you put your hand on the rad directly where the fan is at its most efficient then it should be cool, that is the function of the fan! rads are always hoter where the fan doesn't suck straight thru. Caustic soda is not a good idea. I don't know how to do this, but I do know someone who can, i've seen him do it, I'll see himduring the week-end and gleen the info out of him. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 25, 2002 Author Share Posted July 25, 2002 Originally posted by Nick Harris Caustic soda is not a good idea. I don't know how to do this, but I do know someone who can, i've seen him do it, I'll see himduring the week-end and gleen the info out of him. I was joking about the Caustic Soda...I'm not that mad!!! If you can chat to your contact I would appreciate it. The edges of the rad are too hot to touch... the centre is barely warm....that can't be right surely. Quote Link to comment Share on other sites More sharing options...
Terminator Posted July 25, 2002 Share Posted July 25, 2002 It does sound as if you have flow at the edges of the core but not towards the centre. The engine manual does show how to remove the top and bottom rad tanks to expose the core. Looks like a RPITA using SST's etc. But it may be worth contacting a rad repairer they may be able to unblock it by dismantling. Quote Link to comment Share on other sites More sharing options...
Adam W Posted July 26, 2002 Share Posted July 26, 2002 Why not just try flushing it through with a hose? Quote Link to comment Share on other sites More sharing options...
Alex Posted July 26, 2002 Author Share Posted July 26, 2002 Originally posted by Adam Wootten Why not just try flushing it through with a hose? I have...it stops flowing out crap ...but if you then run more rad flush through it it does it again..the water flows so well round the sides that it never really pressurises the core tubes. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 26, 2002 Author Share Posted July 26, 2002 OH MY GOD!!!! New radiator from Toyota 371 + vat New Radiator from Serck Intertruck (GMRadiator.co.uk for the actual rad maker, Serck are the local disti) Have a guess....nah you won't guess...half price INC VAT! £160+vat is about £190inc Bowled over backwards? Was I ever!! :D :D What's more it should fingers crossed arrive tomorrow! WOW! GM Radiator one to note down - stock replacement same construction inc tanks half the bloody price! Sod this flushing lark! Quote Link to comment Share on other sites More sharing options...
Adam W Posted July 26, 2002 Share Posted July 26, 2002 Good result Alex! Now think of what you can spend all that saved money on . . . Quote Link to comment Share on other sites More sharing options...
Mark Kindell Posted July 27, 2002 Share Posted July 27, 2002 I thought Serck Intertruck or Serck Marstons as they used to be called would be able to do somthing i've used their rads a lot and i've had no complaints . Quote Link to comment Share on other sites More sharing options...
Alex Posted July 27, 2002 Author Share Posted July 27, 2002 Yep indeed Mark, if they were who you mean't then indeed very good so far. They also do Turbo's, Niessen Intercoolers, Oil Coolers etc etc. As the name suggests they are more involved with Truck parts but they have complete catalogues from their suppliers. Just keeping my fingers crossed that the rad comes today Quote Link to comment Share on other sites More sharing options...
Alex Posted July 27, 2002 Author Share Posted July 27, 2002 READ MY LIPS SUPRA MKIV RADIATOR NOT A FECKIN' MKIII ONE!!!!! Arse Quote Link to comment Share on other sites More sharing options...
Branners Posted July 29, 2002 Share Posted July 29, 2002 There was a post on the NZ tech list a couple of days ago, one of them went to change his rad and found its actually an exceptionally well put together 3 core rad, which is never going to be cheap to copy. So looks like you might have to pay a bit of dosh to get once that flows properly. I know the mkiii rads were marginal at the best of times, do a BHG and slightly clog it up and its never going to be right again, so getting a well designed rad might be fairly essential to keeping the mkiv cool. Anybody else notice the temp gauge just never ever moves from just below half way, no matter what you do to the car.... JB Quote Link to comment Share on other sites More sharing options...
GavinL Posted July 29, 2002 Share Posted July 29, 2002 Originally posted by Branners Anybody else notice the temp gauge just never ever moves from just below half way, no matter what you do to the car.... JB I don't recall seeing it move higher than that and I have FMIC fitted. Come too think of it that includes sitting in traffic on a hot day with the AC on. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 29, 2002 Share Posted July 29, 2002 Alex if you fancy a trip to Watford you can borrow my Fluidyne for the 10 of the best. My car won't be ready so you may a well run. Then drop it back to me when you get yours. ( I won't need it for at least 2 weeks.) Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 29, 2002 Share Posted July 29, 2002 Originally posted by GavinL I don't recall seeing it move higher than that and I have FMIC fitted. Come too think of it that includes sitting in traffic on a hot day with the AC on. Only time i have seen mine move higher is when on a rolling road. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 29, 2002 Author Share Posted July 29, 2002 Originally posted by Terry Saunders Alex if you fancy a trip to Watford you can borrow my Fluidyne for the 10 of the best. My car won't be ready so you may a well run. Then drop it back to me when you get yours. ( I won't need it for at least 2 weeks.) Your are indeed a diamond geeza as I believe they say round your neck of the woods! I'll mail you privately As for the needle not moving the Supra was so rock steady no matter what I did is half thie reason this is such a head ache...I just couldn't see it going wrong. Quote Link to comment Share on other sites More sharing options...
Terminator Posted July 29, 2002 Share Posted July 29, 2002 Alex my scanner is fooked, but may be someone can scan EG 421-EG-424 ,fro the engine repair manual. You could disassemble, as it says in the book and put some pressure on each coore pipe. Quote Link to comment Share on other sites More sharing options...
