styggen82 Posted March 31, 2008 Share Posted March 31, 2008 HI just bought a Koyo rad and can you use the stock rad cap on it? seems to fit but the housing( where the cap mounts on to the rad) is 6 mm deeper than stock.... anyone got any experience on this???? Link to comment Share on other sites More sharing options...
Mike M Posted April 1, 2008 Share Posted April 1, 2008 Yep, You need a cap from a mk III supra. Bet the stock caps a bit on the tight side too? All the rad pressure will be lost into the expansion tank if you try and use the stock cap. Paul whiffin on here has them in stock I believe. Cheers Mike Link to comment Share on other sites More sharing options...
styggen82 Posted April 1, 2008 Author Share Posted April 1, 2008 Yep, You need a cap from a mk III supra. Bet the stock caps a bit on the tight side too? All the rad pressure will be lost into the expansion tank if you try and use the stock cap. Paul whiffin on here has them in stock I believe. Cheers Mike thanks, I`ll get one from toyota then:) Link to comment Share on other sites More sharing options...
