super_supra Posted March 31, 2008 Share Posted March 31, 2008 Just started up my face lift tt up after a couple of month's of being stood and the two electric fan's next to the viscous fan started running as soon as the ignition is turned on and carry on running when I start the engine, they never use to run. Has anybody any idea what might be causing this? Cheers Neil Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted March 31, 2008 Share Posted March 31, 2008 Could be the switch has failed or there's a broken wire in the circuit somewhere. The switch is located in the bottom of the radiator at the rear. Link to comment Share on other sites More sharing options...
jazz1 Posted March 31, 2008 Share Posted March 31, 2008 i had this when i took the fan shroud off i forgot to connect the wire that goes under the radiator and that casued my fans to run non stop, after plugging it back in problem was solved. Could be your switch have you checked if it is connected? maybe a rat chewed the wire? Link to comment Share on other sites More sharing options...
scottysupra Posted March 31, 2008 Share Posted March 31, 2008 Do you have the aircon on? The fans work all the time with it switched on. Link to comment Share on other sites More sharing options...
super_supra Posted April 1, 2008 Author Share Posted April 1, 2008 No dont have he aircon on its got a leak on the system so it don't work any way. i will have a lok for the switch at the bottom of the rad and check the conections thanks Neil Link to comment Share on other sites More sharing options...
super_supra Posted April 3, 2008 Author Share Posted April 3, 2008 found the switch at the bottom of the rad it was still plugged in i unplugged it and linked the plug out and the fan's stopped so it looks like i have a faulty switch. thanks for your help Neil Link to comment Share on other sites More sharing options...
