rxv8 Posted March 31, 2008 Share Posted March 31, 2008 hi all a few questions...i have the n/a auto rear end in my chevy supra...can i just change the diff and mount to the n/a prop???or do you have to change to the turbo rear subframe etc etc...and is it all bolt in and are the diff nose/prop bolts the same as the n/a... and finally the reason for this is the turbo rear end has lsd?or any other suggestions would be great...cheers... Quote Link to comment Share on other sites More sharing options...
rxv8 Posted April 1, 2008 Author Share Posted April 1, 2008 boing... Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 1, 2008 Share Posted April 1, 2008 What gearbox are you running? the TT auto one? You will need the TT diff and the TT propshaft as the NA won't fit.. The rear subframes are the same. Not all TT's had an LSD diff Another option would be to keep your current set up and buy the TRD LSD to fit. Nic does them at a reasonable price Quote Link to comment Share on other sites More sharing options...
Jezz Posted April 1, 2008 Share Posted April 1, 2008 The rear subframes are the same. Not quite. TT rear frames have an extra diff mounting point with a bush in it. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 1, 2008 Share Posted April 1, 2008 ... Well the subframes are still the same but the TTs did have an extra diff bushing (The NAs still have the mounting point for it).... You can get the bush from Toyota or Nic does them a bit cheaper Quote Link to comment Share on other sites More sharing options...
Homer Posted April 1, 2008 Share Posted April 1, 2008 Isn't the NA diff a bit weak for a motor thats putting out more torque than a BPU supra? I'm concerned that even the LSD TT auto diff isn't going to be strong enough! (edit - this question isn't neccesarily directed at rxV8) What is your axle code on the VIN? Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 1, 2008 Share Posted April 1, 2008 Isn't the NA diff a bit weak for a motor thats putting out more torque than a BPU supra? Yes, definitely.. I’ve stripped the teeth off two different NA diffs and this was on a stock NA You’ve only got to search on here to see that lots of other NA diffs have failed this way too.. The best bet would be to buy the TRD LSD and fit this inside the NA diff. IIRC the NA diff and the TT auto diff have the same (small) casing. The TRD diff should be good for big power as Envy run it on their drag supra. This is what I’m doing with my NA-TT conversion as I wouldn’t expect the NA diff to hold out for long. As mentioned earlier though, It’s a good idea to fit the extra bushing to the subframe to make the diff more stable and prevent wheel hop Quote Link to comment Share on other sites More sharing options...
Homer Posted April 1, 2008 Share Posted April 1, 2008 Yes, definitely.. I’ve stripped the teeth off two different NA diffs and this was on a stock NA You’ve only got to search on here to see that lots of other NA diffs have failed this way too.. The best bet would be to buy the TRD LSD and fit this inside the NA diff. IIRC the NA diff and the TT auto diff have the same (small) casing. The TRD diff should be good for big power as Envy run it on their drag supra. This is what I’m doing with my NA-TT conversion as I wouldn’t expect the NA diff to hold out for long. As mentioned earlier though, It’s a good idea to fit the extra bushing to the subframe to make the diff more stable and prevent wheel hop Do you happen to know which part of the diff failed? Was it the crown wheel or the diff itself? There are several different crown wheels available, some which appear to be much stronger than others. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 2, 2008 Share Posted April 2, 2008 Do you happen to know which part of the diff failed? Yes, here is a photo of Animal's diff when it broke. 2 of mine have gone in exactly the same way. There was a thread recently where it had happened to someone else so it seems like a weak point on the NA. http://www.mkivsupra.net/vbb/showthread.php?t=142664 http://www.mkivsupra.net/vbb/showthread.php?t=123167 http://www.mkivsupra.net/vbb/showthread.php?t=31785 Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 2, 2008 Share Posted April 2, 2008 I also had another NA diff break on me where the pinion bearing collapsed Luckily i was only travelling at 30mph on a straight road when the rear wheels locked up and the car started to snake around. I daren't imagine what would of happened if i'd of been travelling down the motorway! Thankfully, i've not heard of this happening to anyone else so i guess i was just unlucky... See pics below; Was it the crown wheel or the diff itself? There are several different crown wheels available, some which appear to be much stronger than others. I've dismantled a few NA diffs now and the crown wheels seem to be really strong. I've not seen one with any signs of wearing on the teeth. The one below stood up well to being jammed with pinion bearings! Quote Link to comment Share on other sites More sharing options...
rxv8 Posted April 2, 2008 Author Share Posted April 2, 2008 Isn't the NA diff a bit weak for a motor thats putting out more torque than a BPU supra? I'm concerned that even the LSD TT auto diff isn't going to be strong enough! (edit - this question isn't neccesarily directed at rxV8) What is your axle code on the VIN? will check axle code in next few days...shes on the button now...and sounds bonkers... Quote Link to comment Share on other sites More sharing options...
