Another request for CSS Guru help
fri3ndly
I have run into an annoying problem while developing my layout for a new website.
I was going to post on a css dedicated forum but they all take so long to reply whereas I know someone will help me out instantly here.....touch wood....:D
I have uploaded the index.php and style.css into a zip file attached here and would appreaciate any help.
Basically, the footer will not stay stuck to the bottom, although I do not want it to have a fixed position.
I need it so that whatever content is there it will always be at the bottom of the page and the menu column will always adjust to the size of the page too. You will see what I mean if you just subtract/add content and preview the page.
Thanks!
sorry mate,
ive had a look and the page is all done in layers and i dont use layers so i realy dont know wha im doing with them,i use tables - using tables you could set the actual position of the footer more accurately,
also is there a reason you are using php ?
in the page you show theres nothing that realy needs to be in php,i ask because using php one needs to set up a testing server to view the page after each edit.,maybe standard html would do ?
anyhow sorry i couldnt help.
Hi mate
I use PHP for the development and test it using a server. The extension can simply just be changed from .php to .html
It is done in layers to comply with W3C and as its a lot more simple to look at and for search engines.
I used to do all my coding with tables but would never use them again. Learn to use pure CSS for layout. When a search engine reads your site it should just see standard headers, lists and paragraphs asI believe they find looking for data in tables a lot harder.
No problem, thanks for looking
I see what the benefits are of using CSS,however using pure css for layout is dodgy as it realy relies on upto the minuite browsers,and as you know css has compatability issues across diff browsers,.also table based designs can be viewed by a larger audience.
You can use CSS 'IF' statements to define what code to use for which browser.
CSS is the way forward. Tables should only be used for tabular data ;)
The menu floating to the left is not the issue. Its the footer which is not being sent to the bottom of the menu which is 100% height :(
Yeah, but if you float the menu the footer will move below it where you want it.
You can't set the menu div to be the same height as the content div by giving it a 100% height in css.
:looney:
fri3ndly its because you have position:absolute; on #main-menu. Take this and height 100% off (i assume your only doing this for the background colour). Then do the col one background as a 1px image repeating down the page on the wrapper, this would give the illusion that col one is 100%. Thats how i would do it :) Hope that makes sense :search:
:looney:
Well the menu has a 100% height and it works fine until there is many paragraphs. Thats not the major issue.
I have floated the menu left and cleared it above the footer but it still does not appear to be working :(
Thanks for you help matey
Hi mate
The height needs to be 100% because there will be a lot of content varying in height on every page. The position absoulte needs to be set to have the 100% height otherwise the content all displays below the menu
Nonsense.
See:
microsoft.com
bbc.co.uk
I dont see how table layouts can be viewed by a larger audience since CSS has been supported since IE4 :)
Well ive known about big dffernces between the way Firefox and IE handles CSS for ages,
an easy example is transparencies ?
I think its all down to choice and taste i have my sites scanned and tested and rarely do i have errors or problems.
anyhow,. an interesting read - http://dwank.blogspot.com/2007/11/web-design-with-tables-or-css-whats.html
There is a simple PNG fix javascript for that.
Yep its all down to choice, but tables is very very old school!
Bane of our lives. You have to put browser detection in and override your CSS tags. Nightmare. Roll on IE8.
Don't talk to me about transparencies at the moment. :mad:
IE6 doesn't support transparent PNG so watch that fix also.
Nonsense.
See:
microsoft.com
bbc.co.uk
Pete im not having a go fella,but ive checked bbc.co.uk and its full of tables ?
on there home page alone i found 11 tables used to hold certain images etc
am i getting the wrong end of the stick here or what ? i am quite old :)
Interesting. Their new home page had two small tables and the rest CSS when I viewed it in FF2 just. I wonder if they're doing detection?
