Engine bay wiring - name those plugs!
Homer
Here's a challenge for you all, can you help identify what each of the plugs in the pics below are for?
1. Connects to steering box, not sure what it does
2. Oil level sensor (I think, it attaches to the block)
3. Alternator
4. EGCV VSV or Wastegate VSV
5. EGCV VSV or Wastegate VSV
6. Narrowband O2 sensor
7. Water temp sensor for ECU
8. Water temp sensor for temp gauge
9. Coil pack connector
10. Coil pack connector
11. Coil pack connector
12. Coil pack connector
13. Coil pack connector
14. Coil pack connector
15. IACV VSV
16. EGBV VSV
17. Injector #1
18. Sub Trac TPS
19. TPS
20. Trac stepper motor
21. EVAP VSV
22. Knock sensor
23.
24. Noise filter
25. Igniter pack
26.
27. Fuse box
28. Fuse box
29. injector #2
30. injector #3
31. Either MAP, IAT, or Cam position sensor
32. Either MAP, IAT, or Cam position sensor
33. injector #4
34. injector #5
35. ICV stepper motor
36. injector #6
37. Cam position sensor
38. Either MAP, IAT, or Cam position sensor
39. Vehicle speed sensor
40. Knock sensor
41. Probably autobox
42. possibly starter motor
43. possibly starter motor
44.
The first pic shows the ones at the far end of the loom (go around the front of the engine).
http://img153.imageshack.us/img153/7411/image006ct5.th.jpg
And with more detail:
http://img215.imageshack.us/img215/1707/image003up6.th.jpg
http://img153.imageshack.us/img153/7117/image002hm8.th.jpg
http://img215.imageshack.us/img215/6613/image005fd7.th.jpg
The next set go over the top of the engine (obviously most are coil pack connectors):
http://img503.imageshack.us/img503/6232/21image006iu0.th.jpg
These are around the throttle bodle area (presumably TPS, etc)
http://img153.imageshack.us/img153/2929/image009ok5.th.jpg
I'm not sure where these are from exactly, but they are just down the loom from the throttle body ones above):
http://img215.imageshack.us/img215/852/image013rn4.th.jpg
These ones go to the ignitor, and something else?
http://img215.imageshack.us/img215/1818/image014za3.th.jpg
These I think go somewhere along the intake manifold (presuably injector related?): Two of the plugs are cut off (31 and 32)
http://img215.imageshack.us/img215/4008/image015mg7.th.jpg
The final set go around the back of the engine I think:
http://img527.imageshack.us/img527/6884/image016hh6.th.jpg
2.
3.
4.
5.
6.
15.
16.
17.
18.
19.
21.
22.
23.
24.
25. To Ignitor
26.
27. Fuse box connector 1
28. Fuse box connector 2
29. injector
30. injector
31.
32.
33. injector
34. injector
35. idle speed control valve connector
36. injector
37. injector
38. AEM 3.5 or 5 bar map
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
This is off the top of my head sat at work so I may be wrong on some :D (I've corrected Rob's clanger on the injectors though :p #1 is on a different part of the loom)
3. Alternator
15. IACV VSV
16. EGBV VSV
17. Injector #1
18. Sub Trac TPS
19. TPS
21. EVAP VSV
22. Knock sensor
23. *pass*
24. Noise filter
25. Igniter pack
26. *pass*
27. Fuse box
28. Fuse box
29. injector #2
30. injector #3
33. injector #4
34. injector #5
36. injector #6
40. Knock sensor
44. *pass*
45. Factory nitrous system
46. Incoming meteorite sensor
47. Submersion depth sensor
48. Where are my sensors sensor
Brilliant work Ian, thanks very much mate!!
Lol at the last few, got a bit carried away with the numbers :D
First post is updated, any ideas on the missing ones? The ones in Red need verifying. There doesn't seem to be a Crank position sensor listed, I think that might be 1. or 2.
Pfft, i was just starting it off for you but yeah, you are right, number one is elsewhere :p
Oops, sorry mate, I thought I'd already replied to you - doh!
So, a belated "thanks very much" Rob :D
Either 1 2 or 3 has to the the CPS plug, Ian said 3 is the alternator which makes sense so I guess it must be 1 or 2.
Homer,
Go to, http://www.internetwork.org.uk/supra.html where you can download a complete set of manuals including all the electrical sections which cover plug locations, plug types, wiring harnesses etc etc.
You can then look at your leasure and follow each harness route on yourcar.
Rgds
George
its http://www.internetwork.org.uk/manu/system/system.htm (my site ;)) I woundnt download it as you'll be there for ever unless you want to and Then I'll do a zip'd version for you :D
  • 10 years later...
