gaz1 Posted March 29, 2008 Share Posted March 29, 2008 why are they not the same any thoughts Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 29, 2008 Share Posted March 29, 2008 One has had the TRAC removed and smoothed, i have one just like it;) Link to comment Share on other sites More sharing options...
D8MOA Posted March 29, 2008 Share Posted March 29, 2008 ooooo ones missing the blue pipe Link to comment Share on other sites More sharing options...
gaz1 Posted March 29, 2008 Author Share Posted March 29, 2008 One has had the TRAC removed and smoothed, i have one just like it;) why would you remove it though ooooo ones missing the blue pipe Link to comment Share on other sites More sharing options...
heckler Posted March 29, 2008 Share Posted March 29, 2008 i have the trac removed on my car, and had the Trac butterfly removed aswell. i suppose if your picky, it is a restriction in the air flow... Link to comment Share on other sites More sharing options...
gaz1 Posted March 29, 2008 Author Share Posted March 29, 2008 so this is taken out if not using standard traction control then Link to comment Share on other sites More sharing options...
RobSheffield Posted March 29, 2008 Share Posted March 29, 2008 I have done that too Link to comment Share on other sites More sharing options...
heckler Posted March 29, 2008 Share Posted March 29, 2008 so this is taken out if not using standard traction control then belive so. Link to comment Share on other sites More sharing options...
Steve Posted March 29, 2008 Share Posted March 29, 2008 I have done that too Same here Link to comment Share on other sites More sharing options...
Homer Posted March 29, 2008 Share Posted March 29, 2008 Very tidy job there Gaz Edit - just realised this was a question, I thought that Trac removal was yours! Link to comment Share on other sites More sharing options...
c8sup Posted March 29, 2008 Share Posted March 29, 2008 the two pics are from my car, it has standard trac so if i change the two over will it be ok? Link to comment Share on other sites More sharing options...
T2 MSW Posted March 29, 2008 Share Posted March 29, 2008 Whats the process for deleting the stock traction control? I have just fitted RLTC and would like to remove the stock TC but unsure of the process. Is it just a matter of getting the butterfly removed and removing the ECU, I thought this had ill effects on the auto changes? And I know I could just press the button!!! Link to comment Share on other sites More sharing options...
Homer Posted March 29, 2008 Share Posted March 29, 2008 I've seen it mentioned a few times on here that TRAC removal isn't advised for the auto's as it uses it to close the throttle between shifts (i..e smooth the change). It's 2nd hand info so not sure how correct it is. Link to comment Share on other sites More sharing options...
c8sup Posted March 29, 2008 Share Posted March 29, 2008 thanks homer, would like to find out for sure as i would like to replace mine with the chrome throttle body Link to comment Share on other sites More sharing options...
Steve Posted March 29, 2008 Share Posted March 29, 2008 http://www.mkivsupra.net/vbb/showpost.php?p=88542&postcount=7 This from many moons ago from Matt Harwood, removed butterfly due to RLTC, but it made the changes harsh. Refitted it in the end. I dont suppose it can be good for the autobox with the harsh changes. Link to comment Share on other sites More sharing options...
colsoop Posted March 30, 2008 Share Posted March 30, 2008 Did it to mine quite a while back, angle grinded and smoothed it all off: Link to comment Share on other sites More sharing options...
b_have Posted March 30, 2008 Share Posted March 30, 2008 I chopped mine in half, welded a taperbored section in. Q45 next Link to comment Share on other sites More sharing options...
