hot tub...anyone got one?
cossack
i bought one of the ones you can hire, they cost £200 from ebay, fit 4 people, heat to 40 degrees C and have 90 jets :)
Not had chance to use it yet but cant wait for the summer.
I couldnt see the point of spending £4k on one that you use a few times a year!!
Mike
I worked part time for a swimming pool company over the summer. People with hot tubs were an utter nightmare. The tubs are cheap but the chemicals to keep them clean and the water clear are not cheap and people often don't bother with the chemicals (and then wonder why they feel like their skin is melting etc etc)
"inflates using spa’s motor then just add 860 litres of water"
How the hell are you going to add 860 litres of water at 4am in the morning hammered off your face with a few ladies waiting to jump in for the soak may I ask?
you can keep it filled as it comes with a water tight cover :) so i will fill it and change the water regularly as i dont want to use chemicals, ruin the mood :D
Phew. I was getting worried that filling one up (should I everget one) would put me out of breath before any other EC activities. :)
just wondering if anyone has a outdoor heated hot tub as i was thinking of getting one, do the cost much to run and do you use it much or was it just a waste of money??
They aren't cheap to run by all accounts and those outdoor covers as much good as a chocolate fire guard for keeping heat in - I would expect your bills to rise quite significantly
