Guest MaTTi Posted March 29, 2008 Share Posted March 29, 2008 Just came from a drive, i shut down the car and goes out to larm it, nothing happens, thought it was the battery on the clifford key pad, but nooo. Nothing happens when i turn around the igniton key, no lights (just door light, and stero can be put on). It must be the Clifford alarm that is in the way, how can i disable it to be able to start the car so i can get away from work ??? Have checked, the engine fuses and all seem ok, will check drives side now. Quote Link to comment Share on other sites More sharing options...
tomgeer Posted March 29, 2008 Share Posted March 29, 2008 Check your battery terminals are tight, might be that. Quote Link to comment Share on other sites More sharing options...
Guest MaTTi Posted March 29, 2008 Share Posted March 29, 2008 Cant be the batteri, cuz the rear lamps, and headlights,stereo all works, everything else does not, cant move the seat, no dashlights, nothing. Have checked the interior fuses to now, so im relly stuck here. Quote Link to comment Share on other sites More sharing options...
GlennK Posted March 29, 2008 Share Posted March 29, 2008 With your Clifford alarm there is a guide and a pin code. Follow the guide to disarm the Clifford. It's a bit fiddly but does work. You will need your pin code to hand. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted March 29, 2008 Share Posted March 29, 2008 Even though you are seeing a little power with lights...try the windows. If they are very slow or dont work then battery is flat. If its not this then good luck. Quote Link to comment Share on other sites More sharing options...
JODY T Posted March 29, 2008 Share Posted March 29, 2008 Even though you are seeing a little power with lights...try the windows. If they are very slow or dont work then battery is flat. If its not this then good luck. sounds a little familiar eh Mark.. Quote Link to comment Share on other sites More sharing options...
uzthedentist Posted March 29, 2008 Share Posted March 29, 2008 turn the key, press the button then try again, this happens on my model Quote Link to comment Share on other sites More sharing options...
Guest MaTTi Posted March 29, 2008 Share Posted March 29, 2008 Even though you are seeing a little power with lights...try the windows. If they are very slow or dont work then battery is flat. If its not this then good luck. Are you 100% sure, cuz the windows dont work at all, i have had the batteri on a charger for 1h, and it still same problem. The alarm have a red light on the dash, that does not work to, thought i should mention that. Will try the code bypass thing, when my friends gets the manual, im stuck at work since my car is here with no alarm on it, so i cant just leave it =(, lucky i work in a hotell. Quote Link to comment Share on other sites More sharing options...
and1c Posted March 29, 2008 Share Posted March 29, 2008 Are you 100% sure, cuz the windows dont work at all, i have had the batteri on a charger for 1h, and it still same problem. The alarm have a red light on the dash, that does not work to, thought i should mention that. Will try the code bypass thing, when my friends gets the manual, im stuck at work since my car is here with no alarm on it, so i cant just leave it =(, lucky i work in a hotell. Put it in valet mode as you mention above. If you want the default code for your alarm. pm me the model number. eg concept 600 or whatever You should be ok to leave the car though. If you cant start it with the keyfob and key, then your average car thief will struggle to go anywhere! Quote Link to comment Share on other sites More sharing options...
Guest MaTTi Posted March 30, 2008 Share Posted March 30, 2008 Put it in valet mode as you mention above. If you want the default code for your alarm. pm me the model number. eg concept 600 or whatever You should be ok to leave the car though. If you cant start it with the keyfob and key, then your average car thief will struggle to go anywhere! Just tryed the bypass code, its a concept 300 that i have. Nothing happend relly, its still brain dead. I dont think its the battery, since its a couple of months old, but i have nothing else to go on, i will go buy a new one and try. BTW this happend after i washed the car, i see that the manual says "You need to switch of the system when refulling or washing your car" Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted March 30, 2008 Share Posted March 30, 2008 when you press the window switch do the lights dim on the dash? Have you checked the fuses? The battery may of gone flat if your alternator gave up or could be the battery, but you need to check basics first. Fuses then do lights dim on the dash when pressing window button. Quote Link to comment Share on other sites More sharing options...
Guest MaTTi Posted March 30, 2008 Share Posted March 30, 2008 No the lights seem fine, its only the "door open" light that shows on the dash anyway, and the green igniton light around the key. The stereo works to, and the headlights. Im sure its the alarm, but ive used my Valid code which did not give any response at all. But im still sure its the alarm. When i press the code, i put he turn the key to "ON" and then press the valid code (i have a 2 buttons to do that on, a star button and an unmarked one) So if the code is 4,4,3,8 then i press "star" 4 times and then unmarked once, and then "star" 4 times again, and unmarked again, "star" 3 times and unmarked, "star" 8 times and hold unmarked for 3 sec and release, according to the manual. Result, Nothing happens =( Its a Clifford Concept 300. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted March 30, 2008 Share Posted March 30, 2008 well if it was me and I was out of ideas id disconnect the battery for 10 mins then reconnect it. It might reset whatever the problem is. Quote Link to comment Share on other sites More sharing options...
Guest MaTTi Posted March 30, 2008 Share Posted March 30, 2008 well if it was me and I was out of ideas id disconnect the battery for 10 mins then reconnect it. It might reset whatever the problem is. It was dissconnected while i charged it for 1 hour. Quote Link to comment Share on other sites More sharing options...
Guest piston cruisers Posted May 8, 2008 Share Posted May 8, 2008 i have the same prob i think its the ignition switch i have one on order so ill let you guys no, unless any more idears i have the concept 600 and i took it out thinking it was that but still have no joy, it was intermitent at first but now completly dead any ideas guys? Quote Link to comment Share on other sites More sharing options...
snake Posted May 8, 2008 Share Posted May 8, 2008 Just tryed the bypass code, its a concept 300 that i have. Nothing happend relly, its still brain dead. I dont think its the battery, since its a couple of months old, but i have nothing else to go on, i will go buy a new one and try. BTW this happend after i washed the car, i see that the manual says "You need to switch of the system when refulling or washing your car" you have to put it in valet mode IE turn the key in the ignition on "But not turn the engine over"then switch off .you will hear a beep.The car is now in valet mode.The alarm will not go off so people can sit in the car if you have to put petrol in ,wash it etc. Quote Link to comment Share on other sites More sharing options...
Guest piston cruisers Posted May 9, 2008 Share Posted May 9, 2008 ive taken the switch apart and cleaned all the conections but still the same dose any one no where the iggnition relay is? ps, still got a new switch comming tomorrow so going to try a new one just in case Quote Link to comment Share on other sites More sharing options...
Guest piston cruisers Posted May 10, 2008 Share Posted May 10, 2008 ok guys found the problem. i put the new ignition switch in today but i had the same problem, so.. after being told to put the alarm in vallet mode and it still not working i competely took the imobliser out of the loom and she started first time, so if this helps with anyone else you no its the reley inside the alarm box that thinks it de-imoblised but infact its not... hope this helps guys Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 10, 2008 Share Posted May 10, 2008 ok guys found the problem. i put the new ignition switch in today but i had the same problem, so.. after being told to put the alarm in vallet mode and it still not working i competely took the imobliser out of the loom and she started first time, so if this helps with anyone else you no its the reley inside the alarm box that thinks it de-imoblised but infact its not... hope this helps guys Nice info. Cheers bud. Quote Link to comment Share on other sites More sharing options...
