Cigarette lighter removal
Guest cj748
Guest cj748
As above.
Have done searches on subject, but can't find anything on changing the removable end, (black bit with picture of ciggy on it).
Have bought aluminium one which has screw thread in centre at the back, but original does not seem to undo.:blink:
Any ideas please.
Thanks
CJ
Guest cj748
New ali ones looks really good, so don't want to leave it off.
Bought from EB Design, great work with engraved pic on front.
Guest cj748
Ok. Thanks.
Will pop in to Toyota today and see if they have drawing on micro fish. (i know that is not how it's spelt.):rolleyes:
CJ
are you looing to scrap the old one and replace with a new one? it should come off easy enough
would like the option to revert back to old if need be, didn't just want to smash it to pieces to find I couldn't then fit the new one...
mine must be different cause it comes out handy enough (note i blu mine up must replace it) the way i look at it is if someone put it there it can come back off and even if your stuck to fit your new one modify it so it fits
ps have you pulled the dash apart first?
It's the black plastic part on the lighter that people are trying to remove and swap for an aluminium one, so no dash removal neccessary;)
o rite i get you now lol i thought you were replacing the whole unit thats why i was puzzled:p
Guest cj748
Off to Toyota in the morning will let you know best solution from drawing.
If not i will be using hacksaw and araldite!!:p
CJ
