gaz1 Posted March 27, 2008 Share Posted March 27, 2008 TIPS ON FILLING YOUR CAR(S) (Good information) I don't know what you guys are paying for petrol.... but here in Durban we are also paying higher, up to R7.35 per litre. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every litre. Here at the Marian Hill Pipeline where I work in Durban, we deliver about 4 million litres in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and petrol, LRP and Unleaded. We have 34-storage tanks here with a total capacity of 16,800,000 litres. Only buy or fill up your car in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the fuel, when it gets warmer petrol expands, so buying in the afternoon or in the evening....your litre is not exactly a litre. In the petroleum business, the specific gravity and the temperature of the petrol, diesel and jet fuel, ethanol and other petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps. When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapours that are created while you are pumping. All hoses at the pump have a vapour return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapour. Those vapours are being sucked up and back into the underground storage tank so you're getting less worth for your money. One of the most important tips is to fill up when your tank is HALF FULL. The reason for this is, the more fuel you have in your tank the less air occupying its empty space. petrol evaporates faster than you can imagine. Petroleum storage tanks have an internal floating roof. This roof serves as zero clearance between the petrol and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every litre is actually the exact amount. Another reminder, if there is a fuel truck pumping into the storage tanks when you stop to buy, DO NOT fill up--most likely the petrol/diesel is being stirred up as the fuel is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money. DO SHARE THESE TIPS WITH OTHERS! Link to comment Share on other sites More sharing options...
simbasupra Posted March 27, 2008 Share Posted March 27, 2008 some good tips there:), but is it enough to see an actual difference? Link to comment Share on other sites More sharing options...
dannypunto Posted March 27, 2008 Share Posted March 27, 2008 One of the most important tips is to fill up when your tank is HALF FULL. The reason for this is, the more fuel you have in your tank the less air occupying its empty space. petrol evaporates faster than you can imagine. Petroleum storage tanks have an internal floating roof. This roof serves as zero clearance between the petrol and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every litre is actually the exact amount. DO SHARE THESE TIPS WITH OTHERS! but coulndt u argue that if u drive all the time with a full tank, ie "heavy load " that you are useing fuel to pull in excessive weight?, lugging 60 litres around all the time is a heavy load! Link to comment Share on other sites More sharing options...
Pete Posted March 27, 2008 Share Posted March 27, 2008 Petrol turns to vapour. - So THAT's where it keep disappearing to! I reckon the Supra drinks it way before much of it has chance to vaporise, the Tiger on the other hand always seems to be empty when I go to it. Link to comment Share on other sites More sharing options...
MRX Posted March 27, 2008 Share Posted March 27, 2008 Interesting... thanks mate. Link to comment Share on other sites More sharing options...
SteveR Posted March 27, 2008 Share Posted March 27, 2008 but coulndt u argue that if u drive all the time with a full tank, ie "heavy load " that you are useing fuel to pull in excessive weight?, lugging 60 litres around all the time is a heavy load! Full tank = 70 litres ~70kg You can't drive round with an empty tank, so the 'extra' fuel you would carry by filling your car every time it gets to half full Vs running it to empty then half-filling it, is 35litres = 35kg, not 70kg. 35kg is negligable in a 1,500kg car. Even 70kg isn't that much (~ 1 passenger). Either method is daft IMHO, the extra fuel you'll use going to the petrol station twice as often is unlikely to noticeably outweigh any gains using either of the above methods, assuming that is, that there are any gains to be had - a statement I'm of no means convinced. Link to comment Share on other sites More sharing options...
ivan Posted March 27, 2008 Share Posted March 27, 2008 Petrol turns to vapour. - So THAT's where it keep disappearing to! Same thing keeps happening to my damn brandy too. IMO, the useful bits of the above are filling up first thing on a cold morning and not filling when there's a tanker in. Link to comment Share on other sites More sharing options...
Ark Posted March 28, 2008 Share Posted March 28, 2008 They normally won't let you fill when the tanker's in anyway Link to comment Share on other sites More sharing options...
marc_p Posted March 28, 2008 Share Posted March 28, 2008 Some good advice there, cheers. Link to comment Share on other sites More sharing options...
ivan Posted March 29, 2008 Share Posted March 29, 2008 Dagnamit - I was searching Snopes for something else and came across this: http://www.snopes.com/inboxer/household/gastips.asp Is nothing safe from a Snopes comment? Link to comment Share on other sites More sharing options...
Ewen Posted March 29, 2008 Share Posted March 29, 2008 70 litres of petrol weigh about 52 kg. (petrol has a specific density of about 0.74 ) If you fill your tank to the brim early on a cold morning, what happens when it warms up again ? Wont the 'extra' volume of condensed fuel expand and blow out through the vent ? If you never let the tank go below half full, wont the old fuel constantly 'go off' and constantly dilute the new fuel you put in on top ? Link to comment Share on other sites More sharing options...
grahamc Posted March 29, 2008 Share Posted March 29, 2008 go the South Africans! Link to comment Share on other sites More sharing options...
AndyT Posted March 29, 2008 Share Posted March 29, 2008 @16 Rand to the pound, I wouldn't be worrying. Nice tip on the cold fill up though. JC did it in the Audi Edinburgh test. Link to comment Share on other sites More sharing options...
edge Posted March 29, 2008 Share Posted March 29, 2008 Some good tips there. Thanks Link to comment Share on other sites More sharing options...
Blackie Posted March 29, 2008 Share Posted March 29, 2008 Ideal Link to comment Share on other sites More sharing options...
stevie_b Posted March 29, 2008 Share Posted March 29, 2008 Some interesting tips there, thanks for sharing gaz1. I've got a question for you: is the reason for floating lids on huge petrol storage tanks to reduce the risk of explosion? IIRC, liquid petrol isn't flammable, only the vapour is. By using a floating roof, you reduce the risk of possible explosion. If you fill your tank to the brim early on a cold morning, what happens when it warms up again ? Wont the 'extra' volume of condensed fuel expand and blow out through the vent ? Fair comment. I don't think the expansivity of petrol, combined with relatively small tank capacities (60 litres ish) is enough to cause a blowout in a car's petrol tank. But I'm happy to be corrected..... If you never let the tank go below half full, wont the old fuel constantly 'go off' and constantly dilute the new fuel you put in on top ? I don't think it works like that, thanks to "serial dilution" (nothing to do with cornflakes ). Whenever you drive around, it's likely that any old fuel will be mixed with newer fuel, so you're always using some of the oldest fuel in your tank. The more times you fill up, the more dilute the oldest fuel becomes. Link to comment Share on other sites More sharing options...
hogmaw Posted March 29, 2008 Share Posted March 29, 2008 One way to half your petrol bill is to fill up when the tank is half empty instead of completely empty. Hey presto, your bill is only £30 instead of £60 Link to comment Share on other sites More sharing options...
