Life changing decision
supradibbs
AS some know am a aircraft mech by trade
Anyways i have always wanted to be a pilot and it seems i may get a chance to do it
We operate quite old airplane namely the DC10 which still operate a flight engineer which am more than qualified to do
It seems my supervisor maybe able to get me a position as a 3rd officer(flight engineer) and if i pay for my commercial i could move over to the right hand seat withing 10 months
Now will cost me about 50k to do the full commercial which i could do in about 5 months full time but the good thing about being the flight engineer is i can use the hours as flight hours so will count towards a type rating so would save me a bundle
The downside the supra would have to go and also a small remorgage too
I have small colour blindness which i have been told can be beat by memorising the test book:d
What to do
Thats just great. A few years time I could be on my holiday, flying on a airliner with a colour blind pilot.
Copilot: Err, :salute: .... captain Wayne,... Warning lights are flashing.
Engines over heating sir.
Wayne: No its not. Those lights are green.
;) Go for it.
First dips on the car :)
30k you can pick it up tomorrow
Wrong :(
Grr just typed a reply and IE crashed :angry:
Anyways, thought i'd expand on this.
The Ishihara test is the one you're on about learning which is possible but only if the tester doesn't change the order on you. The first plate is normally "12" because it should be seen by everyone and makes sure that you can actually read :D
After that, there's "transforming plates" and "vanishing plates" etc. If they change the order on these you might struggle depending on the depth of your colourblindness. If it's only slight, you should pass an Ishihara test. If it's deeper than that then you might struggle if they change the order. The plates do as their names suggest:
Transforming - normal trichromat sees one particular number, people who are colour deficient see another depending on whether it's a red / green issue.
Vanishing - normal trichromats don't see a number but deficients do, again the number depends on what deficiency you have.
You can usually tell if you've seen a Vanishing plate as the number still looks a bit "different" to the others. It's tricky though. There's also other things they could use on you besides numbers, like asking you to trace a pattern of coloured dots - you can't prelearn that one :(
Depending on how colour blind you are, if it's only slight then it helps if you know a friendly optician :sly:
If you're slightly colourblind, they sometimes assess you themselves and see if you're still competent and if so, issue a certificate saying you are or they might limit your hours to daylight only. I dunno what they do as we never hear back from applicants that have applied with a known deficiency. I know a lad who i went to school with failed on his vision, i didn't ask him what one though because he's a tw@t :)
If you get through the Ishihara test, it depends what the CAA might want after that:
http://www.academy.org.uk/reference/civilavi.htm
If they still do lantern testing etc, that's not really possible to blag :(
i need to find more information on this as the missus knows 3 comercial pilots who have done this
