Thor dsc/tsd
rick001
what was the problem - I have had the same fault but no one has been able to fix it?
Thanks
The prolem is on the speed sensor/ECU circuit, you have to re-arranbe your wireing slightly behing ODO to fix - (takes 5 mins) its very simple :) If you need to delimit or convert your speedo, this unit is the mutts nutts ;) It can also correct the code 42 when you wire it in :D
