supra steveo Posted March 26, 2008 Author Share Posted March 26, 2008 love the new avatar mate Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 27, 2008 Author Share Posted March 27, 2008 more pictures added to the first post to show the solder, ive decided while changing a part of the dash today to solder on the last bulb slot as it lets me store the kit easier Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted March 27, 2008 Share Posted March 27, 2008 if you have decided to go Reverse El-Glo then i would add LEDs to where the bulbs should be and solder the power wires to one of the bigger bulb slots (and add the LEDs to that slot also) Ok I'm lost. I have ordered the Reverse El-Glo. How easy is it to add led bulbs instead of the regular ones? What is the main benefit? Brighter? I'm all for giving this a go. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted March 28, 2008 Share Posted March 28, 2008 Ok I'm lost. I have ordered the Reverse El-Glo. How easy is it to add led bulbs instead of the regular ones? What is the main benefit? Brighter? I'm all for giving this a go. What does it all mean? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 28, 2008 Author Share Posted March 28, 2008 well if you look at hecklers page it is all on there about the LEDs it is really easy Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted March 28, 2008 Share Posted March 28, 2008 Cheers. For anyone else have a look here: http://www.internetwork.org.uk/led/led.htm Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted March 28, 2008 Share Posted March 28, 2008 Cheers. For anyone else have a look here: http://www.internetwork.org.uk/led/led.htm Cheers. So it looks like I'd better get some of these then: * 6 x 5mm Blue LED's * 6 x 390R Resistors * A soldering iron (and solder) Then I should be able to get it all done. In theory EDIT: Personally I prefer the following method, but all depends how fiddly it is to do: http://www.internetwork.org.uk/led/bulbalt.htm As if I balls it up, I could always do the other mod, and get it right! Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 28, 2008 Author Share Posted March 28, 2008 Maplin is your best bet mate Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 5, 2008 Share Posted April 5, 2008 Sorry for being a dum dum but the white dials... do you need to put dash bulbs in or do you get light from them black connectors on the top of the dials? I want to change my stainless dials as the LED conversion I did has brighter spots on 0-40mph goes dull at 60-80 and bright again beyond that. Cheers Quote Link to comment Share on other sites More sharing options...
supra steveo Posted April 5, 2008 Author Share Posted April 5, 2008 this isn't a LED conversion thread, it is showing how to fit the El-Glo dials for the people who have bought them and the people who are buying them at the minute. EL-Glo dials the whole dial glows up, and needs no leds or bulbs behind reverse EL-Glo needs some LEDs (well from what ive been told)and these need to be soldered to the terminal where the bulbs go the electrical connection makes the dials glow up Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 5, 2008 Share Posted April 5, 2008 this isn't a LED conversion thread, it is showing how to fit the El-Glo dials for the people who have bought them and the people who are buying them at the minute. EL-Glo dials the whole dial glows up, and needs no leds or bulbs behind reverse EL-Glo needs some LEDs (well from what ive been told)and these need to be soldered to the terminal where the bulbs go the electrical connection makes the dials glow up *I know this isn't a LED conversion thread, im asking if you need bulbs to light these up! Im after some El-Glos to replace me stainless dials *Just what I needed to know Quote Link to comment Share on other sites More sharing options...
supra steveo Posted April 5, 2008 Author Share Posted April 5, 2008 ahh right check out the group buy threads then and see what people have ordered or go to http://www.speedhut.com and play with the dial designer there are TRD and a supra logo that are no longer on the site but if you look at the group buy you will see them Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 5, 2008 Share Posted April 5, 2008 Just another question supra steveo, do you have to have the stock black dials behind? I see from the pics that the fuel/temp has a black trip on the side (full beam, handbrake etc) Is this clear on the El-glo but appears black on your pics because the stock one is under? - Hope I make sense Quote Link to comment Share on other sites More sharing options...
supra steveo Posted April 5, 2008 Author Share Posted April 5, 2008 yes they go over the top of stock clocks Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 10, 2008 Author Share Posted September 10, 2008 also guys remember to plug in the dimmer switch before you try to play with the dials coz i sat there like a half wit last night checking every fuse the car had before scratching my head for 30 mins only to clip the dimmer switch up to get them working , i really wanted to punch myself Quote Link to comment Share on other sites More sharing options...
bibblebob Posted September 11, 2008 Share Posted September 11, 2008 Just a suggestion I have done a lot of these on scoobies skylines and supras,would not advise soldering to back of plastic strip. Get a multi metre and turn your lights on with ignition off. With clocks removed put one end of metre to earth and with the live poke in each wire block connector (the wide ones that plug into the back of the clocks) and when you get a full live reading of around 12.5 volts switch the lights off and if the volts zero, this is the wire you need to conect to the red wire comming from the dials relay. The black needs to go to a good earth. Scotch lock not advisable just cut a bit of the plastic back an solder for a good connection. Not had one fail yet. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 11, 2008 Author Share Posted September 11, 2008 its an idea yes and there was a scotch lock supplied and people could trace the wires on the clip and tap in there too it just easier to remove the clocks if you solder to the strip Quote Link to comment Share on other sites More sharing options...
bibblebob Posted September 11, 2008 Share Posted September 11, 2008 Just another question supra steveo, do you have to have the stock black dials behind? I see from the pics that the fuel/temp has a black trip on the side (full beam, handbrake etc) Is this clear on the El-glo but appears black on your pics because the stock one is under? - Hope I make sense If you want your dials fitting dude pm me i'm in HULL:thumbs: Quote Link to comment Share on other sites More sharing options...
Dazzi Posted September 11, 2008 Share Posted September 11, 2008 If you want your dials fitting dude pm me i'm in HULL:thumbs: Did mine ages ago mate, easy job lol Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 10, 2009 Share Posted May 10, 2009 I know this will sound a bit pants, but I only got round to fitting my reverse el-glo dials yesterday, and also forgot to reconnect the dimmer switch! It took ages to figure it out, and Garfy just suddenly remembered it before taking anything else apart! I have just one question. Now that I've got it all in, and it seems to be working fine, the needles on the dials don't light up anymore, and are difficult to see in the dark. Is this what I can expect, or is there some solution to see them on again? Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted May 10, 2009 Share Posted May 10, 2009 Andrew, if you put the led's back into the cluster they will light up the needles. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 10, 2009 Share Posted May 10, 2009 Andrew, if you put the led's back into the cluster they will light up the needles. I did that just now, to see if it made a difference. With the roof off, and being so sunny, I can't tell if it's worked or not, even with a blanket covering it all! I had Heckler's blue LED conversion previously, so all the LEDs should work still. Hopefully! Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted May 10, 2009 Share Posted May 10, 2009 It might be really hard to tell just now, My car had the a blue dash conversion when I bought it. When I fitted my El Glo's I left the existing blue led's in place, the give the needles a nice glow from behind. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 10, 2009 Share Posted May 10, 2009 I will wait until nightfall to see it in its glory. It better work, god dammit, as I've had that dash out of there umpteen times now! Quote Link to comment Share on other sites More sharing options...
pjavon Posted December 18, 2009 Share Posted December 18, 2009 Do El-glo dials not light up the needles then? Was just about to go into the group buy but don't want them if this is the case Any confirm please Quote Link to comment Share on other sites More sharing options...
