soldering stress... why won't the **** solder take?
Mike B
Soldering a new loom onto on O2 sensor.
I have soldered a lot of stuff in the past, and have had the problem of solder not taking - dirty wires etc.
I have 10 perfect condition wire ends, cleaned with meth, scored and sanded, but the solder will not stick!!!! at all!....
They were very hard to cut and, I expect, made from something not normal, but anyone got any idea how to make the solder take.
having a bit of a sense of humour failure I'm afraid... :badmood:
is the answer flux...? yet I have flux cored solder... and no joy at all...!?
The stock loom/sensor wires are coated in some stange waxy sort of cr*p...sorry i cant be more definative. I had exactly the same problem when trying to do the same thing. After ballsing around with 2 different heat irons and numerous rolls of flux i used crimp bullets that came with the new sensor (universal one).
Job is done,
I made sure I had a good twisted overlap, then put the solder ready melted on the iron into the flux and it bonds, feeding in more solder. I got solid connections, but it wasn't simple, and some of them took a couple of attempts.
HKS do sell a bullet pin set, maybe I will re-do and get one ordered up.
Thnx for the advice
Use silver solder, and sounds like you need atleast 75w iron or 100w gun would be better. flux isnt needed if surfaces are clean. prime the tip with solder first. heat the object you are soldering and melt the solder onto the object, not the solder onto the iron, or you will get blobby crap dry joints.
guns are generally better at doing big jobs as they heat the immediate area up very quickly, where as irons tend to take longer to transfer the heat and can end up heat all the object up before the actual temp is required to solder.
