Exhaust diameter.HKS.
SupraHuman
Just been out mate, it's 5", I knew it was, as they are bigger than most other tips.
So 127mm?
Is there any restriction inside the tail pipe, just need to know how long the baffle can be?
HKS do 2 options
1. 120mm diameter x 280mm length
2. 120mm diameter x 140mm length
:thanks:
So 127mm?
HKS do 2 options
:thanks:
I think mine was around 280mm because I used it as a funnel quite a few times.And soon everybody did so it wanished after a few months :cry:
Erm no immediate restriction, but the pipe obviously tapers down at the back where it connects to the silencer.
How do these mount as there is no hole to fasten a small fastener through. Or will the tip need drilling?
I have a hole on my exhaust for a 8mm bolt that held the baffle in place.
