bmx1lew Posted March 23, 2008 Share Posted March 23, 2008 started her up today, she hasnt been started since Thrusday so i warmed her up till the temp gauge hit half way, once she was warmed through the revs drop to 300rpm and the car shakes quite a lot, i have took a video but it dosnt pick it up to well, if watch when i put the camera on the steering wheel you can see it shake, when i got my car in august it never shaked like this, also there's seems to be a sqeek/hipitched sucking noise when i first turn the car which usually last's for say 5 mins then disapears, also there is allot of smoke from the exhaust, however it dosnt smell bad, i have also filmed it. Link to comment Share on other sites More sharing options...
ManwithSupra Posted March 23, 2008 Share Posted March 23, 2008 The Smoke is just looks like normal exhaust steam to me on a cold day, the low engine revs and shaking could be down to a misfire which is probably down to the spark plugs, get them changed and see what happens. Link to comment Share on other sites More sharing options...
RobSheffield Posted March 23, 2008 Share Posted March 23, 2008 error codes? Link to comment Share on other sites More sharing options...
wile e coyote Posted March 23, 2008 Share Posted March 23, 2008 Check coil packs are on nice and tight and check your spark plugs. I had this and a day later it would not start and stink of fuel.Found a coil pack was loose and i changed the plugs Link to comment Share on other sites More sharing options...
DannoSupra Posted March 23, 2008 Share Posted March 23, 2008 Mine used to drop down its rev's with a split vac hose... BUT in theory, with a vac leak, revs go higher!! What about the throttle cable, try adjust the stop on the throttle body Just another something for you to check Link to comment Share on other sites More sharing options...
DannoSupra Posted March 23, 2008 Share Posted March 23, 2008 Rob.... has it got any error codes ??? Link to comment Share on other sites More sharing options...
RobSheffield Posted March 23, 2008 Share Posted March 23, 2008 I think that may be the point im trying to make Link to comment Share on other sites More sharing options...
DannoSupra Posted March 23, 2008 Share Posted March 23, 2008 1st thing i'de do to tbh Link to comment Share on other sites More sharing options...
Pig Posted March 23, 2008 Share Posted March 23, 2008 what are the error codes ? Link to comment Share on other sites More sharing options...
AndyT Posted March 23, 2008 Share Posted March 23, 2008 No worries on the smoke. Cold day 3 litre engine = lots of white steam. Lol I see new cars making more than that. Error codes and post it all up as Rob says. Link to comment Share on other sites More sharing options...
bmx1lew Posted March 23, 2008 Author Share Posted March 23, 2008 i will have to get my mate to plug the thing in to tell me if summit is wrong, if i need plugs who is the cheapest to order from, i might as well get some ik22's ready to go bpu? Lew. Link to comment Share on other sites More sharing options...
Steve Posted March 23, 2008 Share Posted March 23, 2008 Just use some NGK plugs Have a look through here http://www.mkivsupra.net/vbb/showthread.php?t=41927 Just check for error codes first though Link to comment Share on other sites More sharing options...
bmx1lew Posted March 23, 2008 Author Share Posted March 23, 2008 i will try my mates plug in thing im a little lost off with this shorting thing :s Link to comment Share on other sites More sharing options...
Steve Posted March 23, 2008 Share Posted March 23, 2008 bmx1lew said: i will try my mates plug in thing im a little lost off with this shorting thing :s Its easy mate;) Just read through the guide a few times to make sure you get it right Click here for guide Link to comment Share on other sites More sharing options...
jevansio Posted March 23, 2008 Share Posted March 23, 2008 Has anyone thought of checking for error codes yet? Link to comment Share on other sites More sharing options...
Steve Posted March 23, 2008 Share Posted March 23, 2008 jevansio said: Has anyone thought of checking for error codes yet? What a brilliant idea, good plan Link to comment Share on other sites More sharing options...
hodge Posted March 23, 2008 Share Posted March 23, 2008 Does it have any error codes :search: Link to comment Share on other sites More sharing options...
Nic Posted March 23, 2008 Share Posted March 23, 2008 Is it revving normally? Lumpy tickover and vibration could mean it's not running on all cylinders. Link to comment Share on other sites More sharing options...
bmx1lew Posted March 23, 2008 Author Share Posted March 23, 2008 yeah it rev's fine, is that idle normal, i thought it was quite low? I'm going to get some plugs this week so i will keep you posted on what happens, car isnt been used so its all ok so far. Lew. Link to comment Share on other sites More sharing options...
