Fault code - HELP !!!
Diane Abol
Originally posted by Ian C
I haven't encountered that beastie yet - where is it located and what sort of sensor is it?
-Ian
It runs of the cam belt, smaller toothed cog which the belt runs round and a larger cog attached. The two cogs come apart and the in my case the car just stops.
Guest Terry S
J take the crank trigger disc of & spot weld it ( it is in two bits) End of problem. Its rpobably just spinning at the moment. You will see what I mean when you get it off.
How is the Beastie??
