Engine check light on at 60mph!!
rick001
Need some tech help - I have recently had my n/a converted to TT:d, i had a delimiter on the n/a but all seems fine on the TT clocks that are in so i removed the converter/delimeter - now for some strange reason the check light comes on at @60mph and the engine is stalling :search:- i reinstalled the delimiter but still same issue :search:
have u got an aftermarket front bumper? did it used to come from factory with a front spoiler no? my last few had the spoiler removed with a new front bumper and the light always came on over 60mph
I have an after market bumper fitted, did it ever resolve itself?
Any stored error codes?
Have not checked error codes as yet, not done that before but have the "How too" - it only comes on when i reach 60mph!! Prior to this happening the speedo was under registering the correct speed, i was advised to remove the device to see if it corrected the speedo, which it did (cant understand this as its a j-spec TT clock with (now) no converter or delimeter in situ?? Totally baffling :(
The engine loom was changed so if it came from a TT with the active spoiler it might now be reporting an error to the ECU, hence your issue.
As mentioned, the error code should confirm this.
Edit - who did the conversion and why have they not fixed this?
That good news then, i will get it checked out tomorrow - can i cancel the error code if its that and how?
Thanks :D
Thanks :D
The error will continue to be reported until the reason for the fault report is found. If you can so the error code check and confirm it's a spoiler fault we can go from there..
PS: Please see my edit above and respond ;)
