electric supercharger????
liam1
Use the force search button - there's a lot of posts on this, including some technical articles on exactly why it doesn't work (i.e. lack of power). There's a few links to one that actually works, too (in 15 second bursts, with a stack of batteries).
Basically they're garbage, and reduce your power by restricting airflow.
Although someone on here, if memory serves, has installed a supercharger designed for another Toyota/Lexus car with success.
EDIT: Found it - http://www.mkivsupra.net/vbb/showthread.php?t=123865
EDIT: See also http://www.mkivsupra.net/vbb/showthread.php?t=19015
Stop!
These are fantastic, but only work if you use a Veilside front bumper as the angle of the mesh on the near side brake duct created the *perfect* intake vortex...
Hang on - don't you need the Veilside spoiler as well to get traction, once you've got all that power?
BTW - given the 'charger's electric, would installing one of these make the Supra a 'green' car?
Stop!
Yes, Your right. Veilside does indeed "Rock" :sly:
