supraspanner Posted March 21, 2008 Share Posted March 21, 2008 Hi Have a red triangle with ! mark in centre on the rev counter. Anyone know what it means??? This is what happens when you leave the car at your parents house and your dad decides to have a shot!!!! Link to comment Share on other sites More sharing options...
tomgeer Posted March 21, 2008 Share Posted March 21, 2008 It is telling you there is a problem, could be anything, do a search on how to pull the error codes. Link to comment Share on other sites More sharing options...
supraspanner Posted March 21, 2008 Author Share Posted March 21, 2008 Cheers for that will have a look at it!!! Link to comment Share on other sites More sharing options...
robin Posted March 21, 2008 Share Posted March 21, 2008 It comes on when a door or the boot is open, when the handbrake is on or when there is a problem. Link to comment Share on other sites More sharing options...
jaymdee Posted March 21, 2008 Share Posted March 21, 2008 Sometimes it comes on if you go round a corner too fast and the brake fluid level sensor thinks its low. May be worth a check and top it up to the max line Link to comment Share on other sites More sharing options...
molak Posted March 23, 2008 Share Posted March 23, 2008 Sometimes it comes on if you go round a corner too fast and the brake fluid level sensor thinks its low. May be worth a check and top it up to the max line in had that same prob with mine! Link to comment Share on other sites More sharing options...
supraspanner Posted March 30, 2008 Author Share Posted March 30, 2008 Hi folks, Finally had a chance to look at the Supra. Followed the error code post and it recorded no faults. Light has gone out so again. Thanks everyone for all the help. Link to comment Share on other sites More sharing options...
