Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 Had a guy fitting my do-luck body kit today and while fitting the rear bumper there are 3 hole on the defuse to pin it to the underside of the car so he drilled a hole for a self tapping screw and went str8 into the petrol tank its a hole about 2mm is there anything i can do to fix or just sumet to get me by till i can get another tank thanks in advance for any help Link to comment Share on other sites More sharing options...
JamieP Posted March 21, 2008 Share Posted March 21, 2008 Remove empty and weld up the hole? Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 its emptying as we speak is the tank plastic or metal Link to comment Share on other sites More sharing options...
SimonB Posted March 21, 2008 Share Posted March 21, 2008 The fuel tank is plastic isn't it? Link to comment Share on other sites More sharing options...
JamieP Posted March 21, 2008 Share Posted March 21, 2008 Ahh ok never knew that:) Link to comment Share on other sites More sharing options...
robin Posted March 21, 2008 Share Posted March 21, 2008 It is a plastic tank. Maybe silicone sealant would work and there is a product called "petrolpatch" but the area would need to be dry first. I think the only safe fix would be a new tank? Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 that what im gonna do b ut i cant get hold of 1 till after the bank holiday and im ment to be got to york on monday would the silicone last till the or would the pressure shoot it out Link to comment Share on other sites More sharing options...
gaz1 Posted March 21, 2008 Share Posted March 21, 2008 do not use silicon it will not last with petrol, i believe halfords do the petrol patch, but should only be used for emergency use Link to comment Share on other sites More sharing options...
uk-rich Posted March 21, 2008 Share Posted March 21, 2008 does this guy know his arse from his elbow mate ? as this is a rather basic error Link to comment Share on other sites More sharing options...
Mike M Posted March 21, 2008 Share Posted March 21, 2008 Had a guy fitting my do-luck body kit today and while fitting the rear bumper there are 3 hole on the defuse to pin it to the underside of the car so he drilled a hole for a self tapping screw and went str8 into the petrol tank its a hole about 2mm is there anything i can do to fix or just sumet to get me by till i can get another tank thanks in advance for any help Self tapping flat headed screw with an 'o' ring should get you by I would have thought. Not pretty by any means but should do. Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 cheers mike if i used a plastic screw would it be safe to melt the screw head with a souldering iron do you think Link to comment Share on other sites More sharing options...
supra matt Posted March 21, 2008 Share Posted March 21, 2008 cheers mike if i used a plastic screw would it be safe to melt the screw head with a souldering iron do you think don't think you will get it hot enough to melt the tank plastic mate you would be best off getting a bigger screw and heating-it up with a blowtorch then screwing it in this way it will fuse with the plastic as you screw it in and seal the hole Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 sounds like a better option cheers dude Link to comment Share on other sites More sharing options...
robin Posted March 21, 2008 Share Posted March 21, 2008 I would be very careful with any heat sources next to a leaking petrol tank. Link to comment Share on other sites More sharing options...
supra matt Posted March 21, 2008 Share Posted March 21, 2008 I would be very careful with any heat sources next to a leaking petrol tank. YA make sure it not leaking out the hole and wedge the filler flap open so it can breath . Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 ill give it ago cheers if you see parts for sale in the morning you know what happened Link to comment Share on other sites More sharing options...
supra matt Posted March 21, 2008 Share Posted March 21, 2008 Best get a fue buckets of sand and water ready mate lol Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 lol Link to comment Share on other sites More sharing options...
Guest Piston_Broke Posted March 21, 2008 Share Posted March 21, 2008 heating-it up with a blowtorch then screwing it in this way it will fuse with the plastic as you screw it in and seal the hole Be carefull you dont ignite the vapours !!! Have you considered a plastic welding kit , the type used to repair bumpers etc . They work by melting in a compatible peice of plastic to that which your tank is made from ....might be worth taking it to a bodyshop that has the kit and seeing what they can do . Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 do you know of antwhere i can buy a plactic welding kit from Link to comment Share on other sites More sharing options...
Guest Piston_Broke Posted March 21, 2008 Share Posted March 21, 2008 do you know of antwhere i can buy a plactic welding kit from You could buy cheap kit from halfords or similar but i doubt it would be man enough for a permanent repair ....the heavy duty kit used by bodyshops would be my 1st choice and as it will hopefully be a once only use its cheaper to get them to do it , i persume your going to pass the repair costs on to the guy fitting the kit ? The bodyshop may insist that the tank is removed and the fumes evacuated before any heat source is applied , either way i,d take it to a pro as the cost of a poor repair doesn,t bear thinking about Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 21, 2008 Share Posted March 21, 2008 cheers buddy Link to comment Share on other sites More sharing options...
TLicense Posted March 22, 2008 Share Posted March 22, 2008 I take it the guy who is fitting the kit is going to pay for the new tank? I would not be happy if a bodyshop had done something like that to my car.... How's the rest of the kit fitting? Link to comment Share on other sites More sharing options...
Guest coldflame Posted March 22, 2008 Share Posted March 22, 2008 to say its a genuine do-luck kit i think the fit is quite poor actuly he has had to cut at least 3inches from the front so it fitted with my fmic and remove the rear crash bar so it would fit and then when he tighned the bolts up it crack one side so he had to rapair that and the skirts are 1 inch to long so there is a over hang at the front fenders Link to comment Share on other sites More sharing options...
