steb9780 Posted March 19, 2008 Share Posted March 19, 2008 What would people recommend, the Innovate gear or the AEM UEGO? Thanks! Link to comment Share on other sites More sharing options...
Angarak Posted March 20, 2008 Share Posted March 20, 2008 They're both good makes - I have the AEM UEGO and Im happy with it (as a standalone, not wired into ECU), but I believe the Innovate is more responsive. Im sure someone with experience of both will come along shortly Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 20, 2008 Share Posted March 20, 2008 I prefer Innovate stuff, used it for years with no problems, it has a better rich range, (reads lower than the AEM) and also most of the kits have data logging , and also calibrate-able outputs for ECU. Link to comment Share on other sites More sharing options...
bodilx6 Posted March 22, 2008 Share Posted March 22, 2008 I'm having lots of issues with my Innovative LC-1. Keeps dropping its calibration for some reason. I have noticed on innovatives forums that other users are having the same problem and I can't figure mine. It is probably a power issue but everything is installed nicely pulling power and grounding from the 12v/cigarette lighter. Are there any of you who has experienced the same? Link to comment Share on other sites More sharing options...
steb9780 Posted March 22, 2008 Author Share Posted March 22, 2008 I opted for the UEGO in the end, purely for the look of the dial when it's lit up. Thanks guys! Link to comment Share on other sites More sharing options...
uzthedentist Posted March 22, 2008 Share Posted March 22, 2008 AEM UEGO all the way Link to comment Share on other sites More sharing options...
MisterSheen Posted March 22, 2008 Share Posted March 22, 2008 AEM UEGO all the way Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 22, 2008 Share Posted March 22, 2008 I'm having lots of issues with my Innovative LC-1. Keeps dropping its calibration for some reason. I have noticed on innovatives forums that other users are having the same problem and I can't figure mine. It is probably a power issue but everything is installed nicely pulling power and grounding from the 12v/cigarette lighter. Are there any of you who has experienced the same? Very likely to be a ground issue, make sure you use a decent location. Link to comment Share on other sites More sharing options...
Ryan.G Posted March 22, 2008 Share Posted March 22, 2008 I'm having lots of issues with my Innovative LC-1. Keeps dropping its calibration for some reason. I have noticed on innovatives forums that other users are having the same problem and I can't figure mine. It is probably a power issue but everything is installed nicely pulling power and grounding from the 12v/cigarette lighter. Are there any of you who has experienced the same? Seen that many times when they are connected to the Cig 12v The ground offset causes all sorts of issues. Also sometimes the 12v supply is not man enough for the sensor heater and creates error codes. Ground onto the chassis near the ECU. Ryan P.s Innovate always for me but the AEM gauges work fine also Link to comment Share on other sites More sharing options...
bodilx6 Posted March 22, 2008 Share Posted March 22, 2008 Seen that many times when they are connected to the Cig 12v The ground offset causes all sorts of issues. Also sometimes the 12v supply is not man enough for the sensor heater and creates error codes. Ground onto the chassis near the ECU. Ryan P.s Innovate always for me but the AEM gauges work fine also Hey, thanks a lot! So you think i'm loosing the calibration due to bad ground? when you say the 12v supply is not man enough, what would you suggest? Pull directly from battery? I have no issues with the warmup cycle. it seems to work every time. Why ground close to ECU and where is that grounded? Link to comment Share on other sites More sharing options...
bodilx6 Posted March 24, 2008 Share Posted March 24, 2008 bump Link to comment Share on other sites More sharing options...
kieren1234 Posted March 24, 2008 Share Posted March 24, 2008 You are meant to ground onto the engine if possible. I have had countless problems with the lc-1 so i will be opting for AEM next. Link to comment Share on other sites More sharing options...
