SkinnBa Posted March 19, 2008 Share Posted March 19, 2008 A bit of a strange place to list a GTO I know as they generally aren't received very well here! but I need to shift my brothers car for him as it's just sitting on our driveway not doing anything. It has been an ongoing project for him for many years but unfortunately he has lost interest and due to other commitments has decided to sell up. A huge amount of money has been spent making this one of the best GTO's around, the car is mechanically new with many parts being replaced; either OEM or aftermarket uprated parts (see huge spec below!). Roughly 71,500 on the clock which is a mixture of Miles and Kilometers. 60,000 is in Kilometers and the rest in Miles, so the total mileage is 48,782. However, most parts that have been changed only have 500 - 1000 miles on them! Please contact me with any questions you may have, although I may have to refer them to my brother if I can't help. The spec is as follows: 1991 Mitsubishi GTO in Electric Blue - 5-Speed Transmission - 6 cyl 3.0 L Turbo Engine - Twin Turbo - Twin Intercooler - Drivers Air Bag - Digital Climate Control - Alloy Wheels - Anti-Lock Brakes - Cruise Control - Electric Mirrors - Front & Rear Limited Slip Differential - ABS, Remote Central Locking - Electrically Adjustable Drivers Seat - Power Steering - Electric Windows - 6 Speaker Stereo - Active Rear Spoiler - Tilt Steering Wheel - Full Time AWD - Same Phase 4 Wheel Steering (AWS) Work Undertaken (that he can remember, may be more than this): - New Mitsubishi shortblock engine - Heads fully rebuilt - Gearbox rebuilt - New TEC 15G turbos ( capable of approx 25psi ) - NGK Iridium spark Plugs (plus set 1 range colder for when boost increased) - MSD Ignition leads (Red) - K&N Induction Kit - Spec Stage 3 Clutch (Excellent), New Fork and Thrust Bearing - Uprated Kormex output shaft and spool, new transfer case seals - New O2 Sensor - New Propshaft mounts - New Engine Mounts - New Clutch Master Cylinder - New Clutch Slave Cylinder & hoses - Pocketlogger & Knockbox with switch mounted into centre console, allows you to view engine management details while driving also Knockbox shows O2 voltage (rich or lean, Knock count (misfire), engine timing - A-Pillar Pod - Autometer Mechanical Oil Temp, Oil Pressure, Boost gauges mounted into centre console in stock locations (green glow) - Autometer Electrical water temp mounted into A Pillar pod (green glow) - Custom white reverse indiglo dials can change from blue to green - ECU Capacitors uprated by the ECU doctor. - Bozz Speed Front bumper - MK 3 rear light panel - Custom downpipe and decat, only requires basic emissions testing because of year - which it easily passed - TEIN type FLEX suspension (adjusts for ride height and stiffness) - 3G 20 groove front discs - EBC redstuff front pads - EBC blackstuff rear pads - 3SX fully adjustable rear control arms - Alpine CD Player, Pioneer TSG1709 front speakers, Pioneer 6x9 rear speakers (can't remember specific model) - BLITZ Supersound dump valve - Unknown origin aftermarket exhaust - TOAD Ai606 Thatcham CAT1 alarm/Immobiliser with light mounted into a-pillar - WALBRO uprated fuel pump (to 500BHP) - Fuel pump hotwire kit fitted (constant 14v to pump) - 3SX active aero bypass ( allows rear spoiler to automatically rise and fall as front removed for bumper) - DN CHROME intercooler hardpipe kit ( 2" pipes uprated from 1.5") - FSE fuel pressure regulator with gauge - Red Vacuum hoses - GREDDY PROFEC E-01 boost controller with display screen & control - GREDDY E-MANAGE with ignition harness fitted - EK2MFG Fuel Rail loop (bigger diameter fuel pipe from front bank to rear, anodised blue) - RC550 Injectors - Big bore hydraulic lifters (3mm not original 1mm) - Turbo Oil feed and return lines - All new gaskets inc head gasket - ISC Valve removed and cleaned - New radiator hoses - New radiator - New radiator fan motor - New alternator - New oil pump - New water pump - New thermostat - New cambelt, tensioner and idler pulley - Chrome & powder coated GTO spark plug cover - blue rocker covers (sprayed with high temp blue paint) - New oil,filter,fuel filter,diff oil etc... - New gear gaiter - Trust GREX gear knob - Interior recoloured to black (looks so much better) - MOT until end of August 2008 - it's only done 100 miles since the last one!! - Tax expired - New uprated Battery - Just finishing run in period for engine Work left to do : - The bodywork is generally very good for the age of the car, however the front bumper has picked up some scrapes and light damage, not too severe it can be repaired. - Drivers sun visor missing 'Vanity unit', Originally the Greddy display screen was mounted here, but I decided it was too difficult to see when driving, leaving a hole where the mirror and lights used to go. You should be able to get replace this unit without having to get another sun visor at little expense. - E-Manage is running a basic map for low boost (6.5 psi), it is slightly rich and will need retuning by a SPECIALIST or SOMEONE KNOWLEDGEABLE (don't get an idiot to do this or it will cost you the engine) A simply awesome car that just needs mapping to get the most out of it. Please note, the car runs perfectly fine on the basic map and isn't causing any damage to it - it's not as fast as it could be though! Part-Ex considered. Strictly no canvassers or agencies. £5800 £4500 £3500 Video of what she sounds like (note no smoke etc...): Link to comment Share on other sites More sharing options...
supra-lover Posted March 19, 2008 Share Posted March 19, 2008 lovely motor, i nearly bought one of these before the supra Link to comment Share on other sites More sharing options...
JamieP Posted March 19, 2008 Share Posted March 19, 2008 I like that:cool: Link to comment Share on other sites More sharing options...
Dann Posted March 19, 2008 Share Posted March 19, 2008 I am a member of the gtouk and have owned my gto for 3 years now love it mine is also a mk1 and a big project. I can say there is alot of gto's for sale at mo club memebers ones too. You have done alot to it and the spec looks impressive but at 5800 i know it does not sound much but with the amout out there and some other high spec ones going cheaper on gtouk you might be a bit hard pushed at that price to sell it am sorry. the gto's have flooded the market this year with fuel pices etc. have to say thought look very nice. Link to comment Share on other sites More sharing options...
Ian W Posted March 19, 2008 Share Posted March 19, 2008 I am a member of the gtouk and have owned my gto for 3 years now love it mine is also a mk1 and a big project. I can say there is alot of gto's for sale at mo club memebers ones too. You have done alot to it and the spec looks impressive but at 5800 i know it does not sound much but with the amout out there and some other high spec ones going cheaper on gtouk you might be a bit hard pushed at that price to sell it am sorry. the gto's have flooded the market this year with fuel pices etc. have to say thought look very nice. Talk about pi$$ing on your chips Link to comment Share on other sites More sharing options...
Vicky Posted March 19, 2008 Share Posted March 19, 2008 i really like that, i nearly bought one to before the supe Link to comment Share on other sites More sharing options...
SkinnBa Posted March 19, 2008 Author Share Posted March 19, 2008 Cheers for the comments guys, everyone is entitled to their opinion. I haven't looked on gtouk myself, but I know that this car is nearly mechanically new and probably better than the majority hence the higher price. We obviously want to get as much as we can for it as over 20 grand has been put into it. I know you don't get it all back when modifying/uprating cars but it'd be nice to see it go above the 4 grand mark that many dogs are selling for on Pistonheads. Link to comment Share on other sites More sharing options...
Dann Posted March 19, 2008 Share Posted March 19, 2008 well looking and fully reading your spec above you have done all the nessary things to make that engine last another 70 -80 thousand miles before some things need replacing you have changed virtually everything. Is nice to see a well looked after example and I wish you all the luck on selling it pal Link to comment Share on other sites More sharing options...
SkinnBa Posted March 19, 2008 Author Share Posted March 19, 2008 well looking and fully reading your spec above you have done all the nessary things to make that engine last another 70 -80 thousand miles before some things need replacing you have changed virtually everything. Is nice to see a well looked after example and I wish you all the luck on selling it pal Thanks very much. Link to comment Share on other sites More sharing options...
Schtuv Posted March 19, 2008 Share Posted March 19, 2008 Da-da-da-da-daaaaaa ... I'm loving it Shame it can't wait until Dec/Jan whenI'm due for a car change. Link to comment Share on other sites More sharing options...
SkinnBa Posted August 24, 2008 Author Share Posted August 24, 2008 Still trying to shift this, now reduced from £5800 to £4500, no tax or MOT, but the car has hardly moved since the last MOT! Someone please take her, not a single person has come to look at her yet :-( Link to comment Share on other sites More sharing options...
Paul Posted August 24, 2008 Share Posted August 24, 2008 I really like that, shame I've got enough cars already:( Alot of car for that money;) Link to comment Share on other sites More sharing options...
SkinnBa Posted September 11, 2008 Author Share Posted September 11, 2008 Really must go now £3500. It'll be great fun at Santa Pod when mapped. Link to comment Share on other sites More sharing options...
TopgunTT Posted September 11, 2008 Share Posted September 11, 2008 Well cheap for a TT car. Link to comment Share on other sites More sharing options...
SkinnBa Posted September 12, 2008 Author Share Posted September 12, 2008 It is indeed, considering the fact it's pretty much mechanically new! We need it off our driveway though Link to comment Share on other sites More sharing options...
gaz1 Posted September 12, 2008 Share Posted September 12, 2008 ok i will start the bidding £2.2k:D Link to comment Share on other sites More sharing options...
SkinnBa Posted September 13, 2008 Author Share Posted September 13, 2008 ok i will start the bidding £2.2k:D He he he, 2.2K is the best offer so far! Although I've had lots of phone calls this morning, perhaps someone might even come to see it!! Link to comment Share on other sites More sharing options...
SkinnBa Posted September 14, 2008 Author Share Posted September 14, 2008 Sold Someone got a bargain!! Link to comment Share on other sites More sharing options...
razza Posted September 15, 2008 Share Posted September 15, 2008 prey tell, how much did this go for in the end? Looked a nice car, especially for that money.... Link to comment Share on other sites More sharing options...
SkinnBa Posted September 15, 2008 Author Share Posted September 15, 2008 It went for £3500 in the end, the guy that bought it didn't even try an offer as he knew how much money had been put into it. We've got to stick a new MOT on it and then it's gone! at least someone else can get it finished off and enjoy it. Link to comment Share on other sites More sharing options...
