possible upgrade your injectors without using Resistor pack?
randy
Guest Terry S
Yes that should be OK. The biggest I've seen though were 550's from RC Engineering. It would probably be just as cheap to get 2nd hand 550's & a resistor pack. Then if you ever want to use man sized injectors you already have the resistor.
LOL @ 'man sized injectors' :p
Mr. 850's :devil:
It's what you do with them that counts...
Can I put my sensible hat on and say get them flow tested as well? I got a set of brand new 550's from Mr. Toyota himself, and one flowed eratically until it got ultrasonically cleaned. Thus justifying the sixty quid it cost.
-Ian
Is it cheaper to get high impedance injectors/resistor pack than low impedance 550's , Ian?
Or did you do it this way for easy upgrade next time?
Just curious as I fancy some 550's and if they can be swapped without using the resistor pack ............
Guest Terry S
Matt, it's the low impedence injectors that require a resistor pack. The stock J spec injectors are high impedence.
I just got the UK spec 550cc injectors as they were relatively cheap, would suffice for all I want to do with the car, and were a well-trodden upgrade path. This meant I had to install the resistor pack as well. I don't know what other injectors you can get, I didn't bother researching it.
-Ian
OK Guys! I guess we dont need the resistor pack if we use high impedence injectors. I just checked for injectors on http://www.takakaira.com/
click performance parts then go to the side menu and click [POWER] ENTERPRISE PERFORMANCE PARTS. They have injectors for the 2jz-gte which are high impedence and are available in 550cc 650cc and 800cc. side feed year before VVTI/and after !
Retail for $117 a piece.:thumbs: :)
Guest Terry S
Good find. Now all we need is an injector expert to tell us if the high impedence are less controllable then the low. There must have been a reason Mr Toyota changed with the 550's, unless it was a cost thing.
I read something to do with some standalone ECU's, and the minimum pulsewidth at idle - you can't get as good pulse definition with a high impedance injector at really low duty cycles, so you end up with erratic (normally rich) fuelling at idle.
Not 100% certain of the above though - surely a low impedance injector with a resistor "looks" exactly the same as a high impedance injector to whatevers driving it?
Guest Terry S
My stand alone will drive both high & low impedence, you just select what type of injector it is in a menu.
I only assume there is a control problem as nearly all high flow injectors are low impedence. There must be a reason for this. I understand what you are saying about the ECU seeing the same thing with a resistor pack, but you guys do know that the UK ECU is MUCH different to the J-Spec. It apparently(the UK) has additional fuelling & ignition timing maps, which aren't present in the J Spec. I know lots of people have installed the 550's with a resistor pack to a J spec, but only Ian C & possible Paul Whiffin have done it properly as far as I know, using a wideband to tune the AFR. I would be interested to see a long term wideband in the car to see exactly what the ECU is doing.
Guest Terry S
Randy, I don't know enough about injector pulse widths to comment, but there must be a reason for Toyota to spend extra cash going to low impedence & a resistor pack. At the cost of those injectors though I would definitely try it. You will need a S-AFC or similar to trim the fuel. 650's would be ideal as long as you aren't looking to far into the future. What are your HP goals? Also I had sooo much trouble finding side feed injectors, so that in it's self is a good thing.
One other thing, make sure your fuel sytem as a whole is up to this. there is no point having 800cc injectors with a stock pump.
Terry, I am basically looking at 500-550 hp in the future when I upgrade my turbo. So I guess 650cc should be fine? I am already upgrading my pump to a higher flow about 180-200 litres/hr. Will I definately run rich if I did not use a S-AFC? Also pls try to find more info on the advantage of using low Vs high impedence injectors. I don't want to regret anything!:)
If you do it, randy, then get a fuel pressure regulator and possibly look into getting a bigger fuel rail...not sure what the stock one can support...The j-spec and UK spec are the same but they must become a restriction at some point.
Guest Terry S
Fuel rail is not an issue. I have a stock one & it has supported upto 690 bhp without issue. Mine has been modified so it has a -6 inlet at either end & a -6 return in the centre. You can use the stock FPR but I have used an Aeromotive one. The reason I chose the stock rail is that I have an HKS one & it just doesn't look as well engineered as the stock item. When it comes to fuel I am not going to play games. ( Anyone want to make me a offer for the HKS one?)
:rolleyes:
The Stock UK Supra pump is about the highest flowing OEM pump there is. I know Chris Wilson is selling an even higher flowing item. What I would say is be careful you don't buy something like the HKS pump for silly money, which actually flows less than a UK pump. If you are set on only running a single line then an external pump may be best but noisey!
