Getrag Posted January 29, 2005 Share Posted January 29, 2005 I need to get a new 52mm guage as my present one only reads to 20psi. Although I'll be keeping it to 18psi with a ring, I dont want to be reading it at the edge of the guage each time. Anyway, will this one do the trick (£55). It doesnt have a peak-hold which would be nice but looks good and good price. Finally, any other recommendations at a competitive price? http://www.apexperformance.co.uk/catalog/default.php?PHPSESSID=5aa95f6c7cc88024663a0c45b66e3883&manufacturers_id=35&PHPSESSID=5aa95f6c7cc88024663a0c45b66e3883 http://www.apexperformance.co.uk/catalog/images/4703large.jpg Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 29, 2005 Share Posted January 29, 2005 Auto meter boost gauges have been recorded as reading out by upto 5PSi IIRC. Do a search on supraforums as they have tested these gauges. You get what you pay for TBH, I would go for an electronic boost gauge as mine is vrey accurate and doesn't rely on a pipe going through the bulkhead. Link to comment Share on other sites More sharing options...
Getrag Posted January 29, 2005 Author Share Posted January 29, 2005 Ok, thanks. As you can see my guage is located on the left side of the dash with the pipework going through the airvent. So it would be good to keep it mechanical so I can just put the new one in its place. http://www.showoffyourcar.com/cars/TOYOTA/7708.jpg Link to comment Share on other sites More sharing options...
Getrag Posted January 29, 2005 Author Share Posted January 29, 2005 BTTT, opinions guys? Am I best just going for a big expensive electronic one? I liked the idea of keeping the original plumbing. Link to comment Share on other sites More sharing options...
Guest HollyNix Posted January 29, 2005 Share Posted January 29, 2005 You should just stick to the original plumbing and up-grade later, yeah? Link to comment Share on other sites More sharing options...
shaf Posted January 29, 2005 Share Posted January 29, 2005 does it have to be in psi, because i have a used hks electronic one which i could let you have for £75 plus post. pm me for further details Link to comment Share on other sites More sharing options...
hadyn Posted January 30, 2005 Share Posted January 30, 2005 where did you get the pod for your gauge from mate? Link to comment Share on other sites More sharing options...
tDR Posted January 30, 2005 Share Posted January 30, 2005 I've never had a problem with Autometer gauges and my boost one showed identical boost to my GReddy Profec B Spec II controller... the boost displayed was also the same as a calibrated boost gauge plumbed into the car at Dastek on a RR day. AFAIK all the other Scottish SXOC owners had similar findings at the RR days. Cheers, Brian. Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 30, 2005 Share Posted January 30, 2005 Chris Wilson can supply a good quality, accurate, reasonably priced (less than £50 inc P&P) boost gauge. Pic attached. Personally I'm not into spending loads on a gauge that does everything including make the tea, when all you need is an accurate real time reading. There's a lot more exciting things to spend money on. Link to comment Share on other sites More sharing options...
Getrag Posted January 30, 2005 Author Share Posted January 30, 2005 Cheers for the info.. Holly, I would like to get something just now that reads a bit more. Shaf, Would probably like to keep mechanical but thanks a lot for the offer. Hadyn, pod guage came with and I cant see any names on it. Its pretty nifty though. tDR, thanks, that is reasuring. geoffvalenti, cheers, Ill look into those ones. Link to comment Share on other sites More sharing options...
hadyn Posted January 30, 2005 Share Posted January 30, 2005 is the chris wilson gauge pictured above the 52mm type to fit in the clock hole? Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 30, 2005 Share Posted January 30, 2005 I'd go for the Racetech one that Chris WIlson sells, you can get them from Demon Tweeks and companies like them. It would be my choice over the Autometer gauge, as IMHO, the autometer is made to look flashy with the carbon face. I've heard good things about the racetech and I know a lot of Cossies that use them with no problems. Link to comment Share on other sites More sharing options...
hadyn Posted January 31, 2005 Share Posted January 31, 2005 saying that though i thought the autometer gauge i had on my S14 was great, very accurate and did the job. Didnt have peak hold and any bling but functional - and thats all that matters really Link to comment Share on other sites More sharing options...
paul mac Posted January 31, 2005 Share Posted January 31, 2005 Chris Wilson can supply a good quality, accurate, reasonably priced (less than £50 inc P&P) boost gauge. Pic attached. Personally I'm not into spending loads on a gauge that does everything including make the tea, when all you need is an accurate real time reading. There's a lot more exciting things to spend money on. sorry to be negative geoff but i've got one of these hung up on the garage wall, next time i go fishing i'me going to use it as a weight, it was absolute b***x, at full boost it would flutter violently between 0.8 and 1.2 bar the needle was a blur (and it made a horrible noise) and it was unreadable i binned it and got a second hand hks peak and hold which is rock solid and highly accurate, imho if you buy cheap with a boost gauge you will just end up buying twice Link to comment Share on other sites More sharing options...
geoffvalenti Posted January 31, 2005 Share Posted January 31, 2005 sorry to be negative geoff but i've got one of these hung up on the garage wall, next time i go fishing i'me going to use it as a weight, You're not being negative Paul, just speaking from your experience. I've got to say that mine works fine, needle is nice and smooth and easy to read (except when you're screaming along flat out, and daren't take your eyes off the road for a millisecond ) After all is said and done, its only a pressure gauge, fairly low pressure at that, if it can't be produced and sold for under £50, then there's something amiss Link to comment Share on other sites More sharing options...
