Solar Trickle Charger - useful?
michael
  • 4 weeks later...
I'm definitely getting one where I slip my slip & out of action for 8 weeks run down my yellow top optima dead & killed as I forgot to disconnect it :( just brought new one for £175.00 not going to let that happen again hopefully one of these should look after the new one by keeping it topped up while not in use ;)
Let me know what you think. Out of interest, how long can you leave yours sitting before you notice its low?
About 4 weeks from fully charged to struggling to start / flat - I hardly ever get it out for a decent run these days though so hopefully one of these will keep things nicely topped up.
I'm not sure if you've read the FAQ or not Michael, but I spotted this bit:
"Q) Is it normal for this item to put out 22v as mine does? My battery is 50amp do i need a regulator? Regards Dan - Dan Downey
A) Yes it is normal but a 4.8w panel will not charge a 50amp battery you will need a 60 AMP solar panel."
Nicely spotted, I'll leave this one then - cheers :)
