chrisbilling Posted March 18, 2008 Share Posted March 18, 2008 Dear All, i am in the process of installing double decat and i have a question, do i need to re attach the exhaust support bracket? The reason im asking is that the origional 1st cat has a built in flexi joint, but the 1st decat pipe doesn't!! If i install the exhaust support bracket to transmission, then the engine mounts will take the vibration etc . All comments appreciated Chris Link to comment Share on other sites More sharing options...
merckx Posted March 18, 2008 Share Posted March 18, 2008 I would fit it. Link to comment Share on other sites More sharing options...
Mike M Posted March 18, 2008 Share Posted March 18, 2008 I fitted mine although had to remove it to get the 1st cat out in the first place. My thoughts at the time were its there for a reason and thought the whole exhaust weight would then only be supported by the manifold if removed. Link to comment Share on other sites More sharing options...
