RobD Posted March 18, 2008 Share Posted March 18, 2008 if i get an import how much will i be lookin at to get the dials converted to mph? Quote Link to comment Share on other sites More sharing options...
RobD Posted March 18, 2008 Author Share Posted March 18, 2008 anyone? Quote Link to comment Share on other sites More sharing options...
hoff Posted March 18, 2008 Share Posted March 18, 2008 Depends. If it gets the SVA done its a bit. If not you can simply buy a 110mph dial of ebay for about £10. Or you can get a speedo converter for about £90 and a delimiter for similar. Plenty of info on here on this, just have a search:) Quote Link to comment Share on other sites More sharing options...
RobD Posted March 18, 2008 Author Share Posted March 18, 2008 cant i fit the dials out of a uk tt into an import they got to 180mph dont they?! Quote Link to comment Share on other sites More sharing options...
hoff Posted March 18, 2008 Share Posted March 18, 2008 Probably, not 100% sure though. But imports are limited to 112mph and you would still need a speedo converter so it goes up in mph not kph. If you got that then the existing dial will read in mph ie, 100kph will actually be 100mph. Quote Link to comment Share on other sites More sharing options...
Epic Posted March 18, 2008 Share Posted March 18, 2008 Yes UK Dials goto 180 Quote Link to comment Share on other sites More sharing options...
SteveR Posted March 18, 2008 Share Posted March 18, 2008 if i get an import how much will i be lookin at to get the dials converted to mph? Depends how handy you are with a soldering iron How To Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 19, 2008 Share Posted March 19, 2008 Yes UK Dials goto 180MPH so do the El-Glo dials in the group buy Quote Link to comment Share on other sites More sharing options...
georigg Posted March 20, 2008 Share Posted March 20, 2008 Rob, Leave the speedo as is, get a good quality converter for the speedo(ie NOT an Ebay cheapo) and fit............see the tech info page for a description but follow the instructions of however's you buy........I bought from NCS. This will leave you with a 180MPH speedo dial. Changing the speedo dial from a UK car will be expensive! The speedo is driven by a sensor in the gearbox and the speedo converters(ensure you buy the ones that fit behind the speedo, not the Ebay cheapo's that fit at the gearbox), which output a voltage signal that varys as speed......voltage increases with speed, and the head responds to the signal. This will also change the mileometer to reading in miles but you will need to have the circuit card for the mileometer changed to show "miles" from "KM" Hope this helps. Quote Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Share Posted April 25, 2008 I have a 320kph TRD speedo dial? I thought imports only had 180kph speedos? Quote Link to comment Share on other sites More sharing options...
SteveR Posted April 25, 2008 Share Posted April 25, 2008 I have a 320kph TRD speedo dial? I thought imports only had 180kph speedos? Sounds like it's been converted (and probably delimited?) and simply fitted with kph dials. Same difference as 180mph. Quote Link to comment Share on other sites More sharing options...
