aerial
hulse
Same thing happened on my celica if it's the same setup, sounds like the toothed rod has broken on the ariel shaft, you can get a new ariel mast from Toyota,
its easy to fix
take out the unit and open it up
remove the broken bits of shaft
clean it up inside and re grease
put the unit back in the car and connect it up
switch the radio on and wait until the motor stops
now feed the toothed shaft into the ariel and get someone to to switch the stereo off, the gears should catch the shaft and pull the ariel back into the unit.
