couv3z Posted March 17, 2008 Share Posted March 17, 2008 tried searching but it seems to bring up for sale items, is there a guild to door card removal? Quote Link to comment Share on other sites More sharing options...
Scott Posted March 17, 2008 Share Posted March 17, 2008 Its a piece of p*ss to take off the doorcards buddy. http://www.internetwork.org.uk/Dash%20Conversion/doorrem.htm Scott =op Quote Link to comment Share on other sites More sharing options...
heartworm Posted March 17, 2008 Share Posted March 17, 2008 I managed it, and im really crap with cars, just undo all the bolts and they just come straight off. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 17, 2008 Share Posted March 17, 2008 Yes, dead easy, Just remember that the small black plastic fastener things come out by pressing the middle bit in. I didn't know that the first time, and cracked one of them. All other fixtures are self-explanatory. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 10, 2010 Share Posted February 10, 2010 I know before you say it ... its a hugley old thread but had to revive it I tried to remove my door cards yesterday and get to look at my central locking issue and i cant seem to get it off , got it to the stage where i can pull it off at the bottom. i have unscrewed all the bolts etc but the plain black plastic covers( without the tiny hole) i just feel they will snap if i pull them hard Will they be ok to pull or is there anyway of poping them out easier ?? cheers guys Quote Link to comment Share on other sites More sharing options...
bamboo rocket Posted February 10, 2010 Share Posted February 10, 2010 http://www.internetwork.org.uk/kit_inst/doorrem.htm Use this guide - sounds like there still is one or more screws left Quote Link to comment Share on other sites More sharing options...
deathmonkey Posted February 10, 2010 Share Posted February 10, 2010 I know before you say it ... its a hugley old thread but had to revive it I tried to remove my door cards yesterday and get to look at my central locking issue and i cant seem to get it off , got it to the stage where i can pull it off at the bottom. i have unscrewed all the bolts etc but the plain black plastic covers( without the tiny hole) i just feel they will snap if i pull them hard Will they be ok to pull or is there anyway of poping them out easier ?? cheers guys As in the black plastic clips? They're pretty flimsy things anyway. Just push the middle bit in iirc? Honestly not a difficult thing to do mate, and if I remember right, the top of the card hooks over the door, so you need to lift it as well as pull? Just thought I'd mention that as you said you could pull from the bottom. Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 10, 2010 Share Posted February 10, 2010 From memory: 3 push in fasteners on the end of the card 4 /5 screws along the bottom near the sill one screw in the compartment / door pull. One last screw that sits behind the door handle (think you have to remove this) Once all undo, you should be able to lift the card off (upwards) Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 10, 2010 Share Posted February 10, 2010 Yep, removed all the screws , as i read a guide on here its the plain black plastic popper thingys with no push-in hole. i take it they just pop out ? cheers for the help again Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2010 Share Posted February 10, 2010 Yep, removed all the screws , as i read a guide on here its the plain black plastic popper thingys with no push-in hole. i take it they just pop out ? cheers for the help again where are the poppers? Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 10, 2010 Share Posted February 10, 2010 top left of the drivers door, the place that gets covered by the dash once the door is closed. Hope thats a good enough description Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 10, 2010 Share Posted February 10, 2010 top left of the drivers door, the place that gets covered by the dash once the door is closed. Hope thats a good enough description They are just plastic covers with a screw hidden underneath, i used a very small flat headed screwdriver to slide behind the plastic cover and with a twist they just pop off. Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2010 Share Posted February 10, 2010 top left of the drivers door, the place that gets covered by the dash once the door is closed. Hope thats a good enough description As Andrew K mentioned... the just cover which "pop" off - just use a flat blade screwdriver and dont be scared to use a bit of force! Quote Link to comment Share on other sites More sharing options...
marc_p Posted February 10, 2010 Share Posted February 10, 2010 http://cdn1.knowyourmeme.com/i/7131/original/1218737914_hit-it-crowbar.jpg Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 10, 2010 Share Posted February 10, 2010 http://cdn1.knowyourmeme.com/i/7131/original/1218737914_hit-it-crowbar.jpg haha thought did cross my mind ok guys cheers for all the help, i will crack on it tomoz afternoon... if the SNOW holds out. Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 11, 2010 Share Posted February 11, 2010 Just push the centres in and they will come out. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 11, 2010 Share Posted February 11, 2010 yer i know how the push in ones work, i was trying to pull off the black cover over the screw haha silly me Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 11, 2010 Share Posted February 11, 2010 (edited) Right then ... Finally got door cards off and checked all connections and dried everything i could see with a hair-dryer , But it still hasnt done anything funny thought though... when i press the unlock button in the car , it unlocks fine but there is a ticking noise coming from the passenger air vent , which is where the relay is ( or so iv been told ) and when i press the lock button theres no sound at all.. this leads me to believe ive narrowed it down to a faulty relay box. I took the bottom glove box out (facelift 97) and tried to find the box but to no avail, its covered with plastic parts and random things i have no idea about ... question is how the hell do i get it out or at least get to it ? cheers again Edited February 11, 2010 by Lee_e (see edit history) Quote Link to comment Share on other sites More sharing options...
Matt H Posted February 11, 2010 Share Posted February 11, 2010 Sounds like you should have someone that know something look at it!!! Quote Link to comment Share on other sites More sharing options...
Lee_e Posted February 11, 2010 Share Posted February 11, 2010 Sounds like you should have someone that know something look at it!!! Does seem that way I admit that im not that confident enough to go "fiddling" with things, and as its my daily drive, i dont really wanna be messing around with stuff. Might go see someone at AFR next week, see if they can have a butchers, cheers for the help and im pretty sure this thread can be burried again Quote Link to comment Share on other sites More sharing options...
