Trig Posted March 17, 2008 Share Posted March 17, 2008 and the CO poisoning would be due to the seal perishing around the burner, the newer ones had the seals fitted andthere is a seal kit which should have been fitted by the installer/manufacturer by now. Link to comment Share on other sites More sharing options...
mkirby Posted March 17, 2008 Author Share Posted March 17, 2008 the only number i could find was this - V116726 Mike Link to comment Share on other sites More sharing options...
Fargo Posted March 17, 2008 Share Posted March 17, 2008 I thought that this was a combi (as in sealed system)? I think you will find that it gets scaled on the hot water side as well as the heating side, especially if they havent got a scale reducer installed. true, but cant say ive heard of anyone powerflushing/chemically treating the domestic side. and the CO poisoning would be due to the seal perishing around the burner, the newer ones had the seals fitted andthere is a seal kit which should have been fitted by the installer/manufacturer by now. can also be via a damaged/perished flue, the seal kits will only be fitted if/when someone comes round, ie British Gas has a program setup whereby all Valliant boilers of a particular type are having the door seals replaced (to the cost of the manufacture of course), but i have not heard of such a thing going on with the powermax. Link to comment Share on other sites More sharing options...
Scoboblio Posted March 17, 2008 Share Posted March 17, 2008 Interesting, we have this exact same boiler and it's........rubbish! Keeps venting water outside because it complains that it's over pressure, then the pressure will drop too low and it locks out. Several stupid a-hole plumber visits later and a few replacement parts, and we're still no closer to finding out what's causing it. We can't even get a bath full of hot water out of ours either. Luckily we rent our house, so it's not our problem. Link to comment Share on other sites More sharing options...
Trig Posted March 17, 2008 Share Posted March 17, 2008 true, but cant say ive heard of anyone powerflushing/chemically treating the domestic side. can also be via a damaged/perished flue, the seal kits will only be fitted if/when someone comes round, ie British Gas has a program setup whereby all Valliant boilers of a particular type are having the door seals replaced (to the cost of the manufacture of course), but i have not heard of such a thing going on with the powermax. no one powerflushes the water side for the reason i said before and its cheaper to replace the heat exchanger yeah them vaillant seals are a nightmare!! my last company i worked for were contracted out to change them. i was doing 12 a day! so boring! but the powermax (the older models) had a similar problem too. few years ago now i think. Link to comment Share on other sites More sharing options...
Trig Posted March 17, 2008 Share Posted March 17, 2008 Interesting, we have this exact same boiler and it's........rubbish! Keeps venting water outside because it complains that it's over pressure, then the pressure will drop too low and it locks out. Several stupid a-hole plumber visits later and a few replacement parts, and we're still no closer to finding out what's causing it. We can't even get a bath full of hot water out of ours either. Luckily we rent our house, so it's not our problem. that sounds like it could be the expanssion vessel. if it overpressurises above 3 bar, the pressure relief valve will open and let the water from the heating system out. a worn out/perished seal on the diaphram inside the expanssion vessel could cause this. Link to comment Share on other sites More sharing options...
Scoboblio Posted March 17, 2008 Share Posted March 17, 2008 that sounds like it could be the expanssion vessel. if it overpressurises above 3 bar, the pressure relief valve will open and let the water from the heating system out. a worn out/perished seal on the diaphram inside the expanssion vessel could cause this. Thanks, will pass that on to the brainless moron plumber if I see him again. Mind you if I see him again, it'll probably be to ask why I had to download and give him an instruction manual last time! Oh and sorry for the Link to comment Share on other sites More sharing options...
Havard Posted March 17, 2008 Share Posted March 17, 2008 Thanks, will pass that on to the brainless moron plumber if I see him again. Mind you if I see him again, it'll probably be to ask why I had to download and give him an instruction manual last time! Oh and sorry for the That is defo a pressure vessel fault!! Sounds like the diaphragm has deflated or burst!! H. Link to comment Share on other sites More sharing options...
Fargo Posted March 17, 2008 Share Posted March 17, 2008 no one powerflushes the water side for the reason i said before and its cheaper to replace the heat exchanger yeah them vaillant seals are a nightmare!! my last company i worked for were contracted out to change them. i was doing 12 a day! so boring! but the powermax (the older models) had a similar problem too. few years ago now i think. yeh but easy money init lol. now powerflushing....thats booooring. Link to comment Share on other sites More sharing options...
Trig Posted March 17, 2008 Share Posted March 17, 2008 yeh but easy money init lol. now powerflushing....thats booooring. amen to that Link to comment Share on other sites More sharing options...
