JustGav Posted March 29, 2008 Share Posted March 29, 2008 I cut the 4 wire inside the ECU and and join the 2 wire outside. When I conneded the 4 wire and still left the 2 wires joins it stated again. I need another ECU It may help a lot starting with a new ECU but another worry is what has been changed on the loom? Hopefully they have kept their hands off everything apart from the ECU. Link to comment Share on other sites More sharing options...
flyby Posted March 30, 2008 Author Share Posted March 30, 2008 Have you got pics showing how the 4 wires inside the ECU are connected, have they broken any tracks on the main circuit board. It looks like they might be sending a modified voltage to the intake temp sensor input, by tricking the ECU you could cause it to run richer or leaner. I have looked if they broken any tracks on the main circuit board, but cant find any. When i start it it runs very rich lots of black smoke. Link to comment Share on other sites More sharing options...
Wez Posted March 30, 2008 Share Posted March 30, 2008 I have looked if they broken any tracks on the main circuit board, but cant find any. When i start it it runs very rich lots of black smoke. This might be due to the way they have fiddled with the inlet temp signal. Have you put the car back to how it was, does it run ok like that? Link to comment Share on other sites More sharing options...
JustGav Posted March 30, 2008 Share Posted March 30, 2008 Well it wont start whitout this small borad of electroniks. LM358 - Op Amp - http://www.national.com/ds/LM/LM158.pdf L7808 - Voltage regulator - http://www.chipcatalog.com/ST/L7808CP.htm Just trying to work about the circuit board wiring..and hopefully have a half clue of what it does. Link to comment Share on other sites More sharing options...
matt k Posted March 30, 2008 Share Posted March 30, 2008 Have you checked under the bonnet to see if any fiddling has been done under there? Link to comment Share on other sites More sharing options...
flyby Posted April 1, 2008 Author Share Posted April 1, 2008 I found a ecu from a UK TT auto 1996 (89661 14661 ) does it work on mine UK auto TT 1994 (89661 14660 ) ? Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 1, 2008 Share Posted April 1, 2008 Hmmm, wonder if one of the envy boys would be willing to pop past and enquire how the modification works (if they are still trading?) Different Newcastle Gav, thats Under-Lyme, Staffordshire. Gaz. Link to comment Share on other sites More sharing options...
