reprogramed by turbosystem
flyby
  • Replies 56
Posted Images
Hmm..
http://www.turbosystems.co.uk/products_frames.htm
I didn't think it was possible to reprogram the ECU?
Without looking up the wiring diagram I'm not sure why they've connected two ECU wires together. That's a bit odd. The wire leading off doesn't seem to return either?
the two wire is join buy one wire from the buttom, and then the button is push, that are grunded..
yes it is strange.That is properly why it dont work. I only get 0.4 bar bost on turbo one and then 0.8 on turbo two.. not mutch of a tuning.... :)
  • 2 weeks later...
Hmm..
How do you normaly chip a ecu?
Any pictures?
I thing i want to go back to normal, and get a boost crontroller and a FCD.
Looks like a white/blue and green/brown wire have been spliced and then possibly grounded on switch activation.
Very odd, we need to know what the wires are to work out what they might be trying to do.
ETTC would be a strong possible...
Could it be one of those daughter board additions that we saw the other week here?
I seriously doubt some UK outfit would go to the bother of making one (or even if they have the skill), but it's a possibilty isn't it?
Might be worth splitting the ECU open to see if anythings been touched inside. Does anyone know if there is some sort of seal to see if it's been opened before?
Yes, they are a right pig to get open and it should be easy to tell visually if someone has had it open before.
An awe inspiring mod that allows you to stop the first turbo for coming and saving it up for big kick when #1+#2 come in together giving you that impression the car has more power (and as Alex says added snake oil) :)
Oh my... I got this problem whit boost on turbo #1, only 0.4 bar and whit turbo #2 kicks in i get 0.9bar.... :blink:
is it possible to opben whit normal tools?
It looks like it is diffult to unscrew some of them.(connector)
I opened a VVTi one once, just a few screws and that was about it. Mind you, it had been open once before.
