Seriously nice R32 GTR, one of the best
Paul Whiffin
Dazza's R32 is currently up for grabs, detuned engine spec to what was seen in Banzai magazine but still very impresive. The car itself is one of the cleanest R32's you'll see anywhere, Banzai magazine thought it was the best R32 in the world. More pics to follow soon, check out the spec.
Nissan Skyline R32 GTR, 2600cc, 55km, 1991, will produce around 600bhp, Estoril blue respray, Do-luck sideskirts, Rear side spats, Carbon front splitter, Color and polish engine bay, Custom turbo to inlet pipe work, Greedy Type R BOV, R32 Early block, Fully balanced bottomend, R34 GTR Nur spec crank, Wiesco pistons, Eagle H beam rods ARP rod bolts, HKS 272 Stage 2 cams, 1.2mm HKS headgasket, Tomei Baffeld/Gated sump, HKS Tripple plate clutch, Trust T78 33D Turbo , OS RB30 T4 Manifold, 4" stainless downpipe, Stainless Exhaust, 60mm Wastegate, 50mm Coolmax alloy rad, Alloy power steering tank, Hurst line lock, Uprated front mount IC, Trust 16row oilcooler, Samco water hoses, Carbing front & rear strut braces, Apexi PFC, RB25 AFM's , Adj cam gears, HKS solid gearbox side mounts, Nismo engine & gearbox uprated mounts, Nismo 680cc Inj, Nismo Regulator, Nismo Big Slave, Nismo Braided hose, Tomei 280 Fuel pump poss x2, D speed clear front indicators, Garage Defend carbon slam panel, Alloy PS tank, Hurst Line lock, Cusco brake stopper, HID, Superpro bushes, KAD 6 pot calipers 365mm AP discs Ferrodo DS3000, Rear DBA slotted discs porterfield R4 pads, Goodridge braided brake lines, Essential Hicas lock out bar, JAM Racing circuit coilovers, Tie rod bars, Ikeya steering rack ends, adustable top arms, Compomotive 18x10 alloys resprayed in mat black very nice!!!, 265x30 Yokohamma A048, Alloy wheel nuts, Corbeau Carbon Kevlar racing buckets, interior retrimmed in alcantra black inc doorcards , Bride seat rails, Momo race steering wheel, Nismo gearknob, Nismo quickshift, Nismo mats, Greedy Profec II boost controller, Defi Gauges+unit : oil press, oil temp, water temp, fuel press, boost, EGT., AEM Wideband AFR, Clifford cat 1, Tracker, Pioneer DVD headunit, Phonix gold amp, Kenwood spk, Red Top 40 Racing Battery and alloy holder, this is one of the cleanest R32's in the world, got to be seen to be believed, £18,500
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza front.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza front2.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza front3.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza side.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza side2.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza rear.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza engine.jpg
http://www.whifbitz.co.uk/images/carsforsale/forumpics/dazza front engine.jpg
