My heating is broke!
Guest SupraKingNI
Guest SupraKingNI
Hey guys right just got me motor back from garage and the heating does work! Yes i should take it back but its been in for 4 weeks could it be something just not connected??
Whats actually the problem with it? is it not heating up at all or are the fans not working? It's not too clear from your posts. Always handy to post a bit of info on the problem rather than "heating is broke".
If it's no fans then possibly they haven't plugged connector back in or the cigarette lighter fuse has gone as this knocks out the heating controls (Do the lights on the heater switches work?).
If it's no heat then possibly the heater matrix which looks like it's a bit of a pain to fix.
Guest SupraKingNI
It was the fuses after all nice easy job although ended up taking out the dash panel and everything!! Oh well good experience and easy to do in the end!
  • 2 months later...
Guest supra94na
Hi, this is my first post and I'm looking for some help here. The heater/fan is dead and it is no longer back lit. Also as mentioned above, the cig lighter is dead. I have tried to find the fuse box under the dash, but I can't locate it anywhere! What exactly should I be looking for? A picture/photo for someone would be a major help! Is it possible that a previous owners removed the fuse box and soldered all the wires together? I have an N/A '94.
Guest supra94na
I did that earlier and manged to located a box about 12cm long by 8cm wide by 2cm deep. It wasn't firmly attched to anything, simply held in place by the mass of wires surrounding it. I assumed it was the theft deterent box, but I may be mistaken. On the box there was a five letter word (can't remember it exactly but it started with the letter A).
