DMY23 Posted November 27, 2015 Share Posted November 27, 2015 Could pm me a price posted (UK) for this? Thanks Just to make sure were talking the same part, this is the spring i need. [ATTACH=CONFIG]207048[/ATTACH] Hi keron, did you have a price on this part? Thanks. Quote Link to comment Share on other sites More sharing options...
keron Posted November 27, 2015 Author Share Posted November 27, 2015 Hi, special order from Japan, £20 plus del The clutch pedal Spring dmy23 Quote Link to comment Share on other sites More sharing options...
keron Posted November 27, 2015 Author Share Posted November 27, 2015 Keron, do you have any of the factor central locking boxes. Black box that is found under the drivers seat with a loom running up to the dash? Do you also have any illuminated drivers side key locks? I should have the cdl boxes... Not sure about the d.side illumination ring...I'll have to check Any window strips keron ? The long black plastic strip that sits on the outside between the window and door. Must be in excellent condition with all end caps intact. I'll check for you tomorrow/Monday mate Quote Link to comment Share on other sites More sharing options...
DMY23 Posted November 28, 2015 Share Posted November 28, 2015 Hi, special order from Japan, £20 plus del The clutch pedal Spring dmy23 Hi keron, can I order one of those please. Could you PM me final amount inc delivery, and PayPal details. Quote Link to comment Share on other sites More sharing options...
keron Posted November 28, 2015 Author Share Posted November 28, 2015 Yeh sure. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted November 28, 2015 Share Posted November 28, 2015 Don't suppose you have a Manual Gear Surround you will let go Keron Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted January 16, 2016 Share Posted January 16, 2016 Pm sent keron Thanks Quote Link to comment Share on other sites More sharing options...
KamaSupra Posted January 19, 2016 Share Posted January 19, 2016 Wondered if you could help?.... I have a 1996 facelift Supra which has the airbag panel on the passenger side above the glove box. The airbag panel has become dog eared in the corners, so I bought an airbag from another Supra. This panel was from a 1997 facelift Supra and it says 'Supra' on this airbag panel unlike my 1996 one. The wiring plugs seem to have different connections to one another. I remember when swapping the steering wheels over, from it's original facelift wheel to the carbon facelift wheel. I bought a wiring harness from Toyota which let me fit the carbon wheel to the exciting plug. So my question to you is.... Do you know if there is a wiring harness to use with the existing 1996 airbag plug to make it fit this 1997 airbag panels plug? Cheers Quote Link to comment Share on other sites More sharing options...
Snowyowl123 Posted January 30, 2016 Share Posted January 30, 2016 Hi Keron. My drivers electric seat has the usual problem and is only working on one side ( it's missing the white plastic end plug on the other side) . Would you have any replacement rail parts or pre face lift working seats , or pair of leather or a face lift interior? Many thanks Andy Quote Link to comment Share on other sites More sharing options...
Annabella Posted April 21, 2016 Share Posted April 21, 2016 Hi Keron - battery clamp received today, installed, many thanks. Quote Link to comment Share on other sites More sharing options...
Karl M N Posted May 14, 2016 Share Posted May 14, 2016 Hey Keron, don't suppose you have any UK spec engine management clusters do you? Quote Link to comment Share on other sites More sharing options...
keron Posted May 14, 2016 Author Share Posted May 14, 2016 Hey Keron, don't suppose you have any UK spec engine management clusters do you? Hi Karl, I may have... ill check by Monday for you... Quote Link to comment Share on other sites More sharing options...
Why T Posted May 16, 2016 Share Posted May 16, 2016 Keron got any clear cam cover? Quote Link to comment Share on other sites More sharing options...
JordanC Posted May 16, 2016 Share Posted May 16, 2016 Hi Keron, Do you happen to have any rad shrouds in good condition?? Mine is a bit worse for wear! Quote Link to comment Share on other sites More sharing options...
keron Posted May 16, 2016 Author Share Posted May 16, 2016 Keron got any clear cam cover? /QUOTE] sorry ive ran out of these now.... don't think ill get any more either.... very cheap on ebay..... Hi Keron, Do you happen to have any rad shrouds in good condition?? Mine is a bit worse for wear! sorry I find these are extremely hard to get used.... without any damage.... new are about £150ish iirc... Quote Link to comment Share on other sites More sharing options...
Why T Posted May 16, 2016 Share Posted May 16, 2016 Thanks buddy Fortune03 Aerotop manual single. 'Speed doesn't kill' Quote Link to comment Share on other sites More sharing options...
JordanC Posted May 16, 2016 Share Posted May 16, 2016 sorry ive ran out of these now.... don't think ill get any more either.... very cheap on ebay..... sorry I find these are extremely hard to get used.... without any damage.... new are about £150ish iirc... Oh not as pricey as I thought, thanks Keron Quote Link to comment Share on other sites More sharing options...
SUPRAPAUL Posted June 28, 2016 Share Posted June 28, 2016 hi do you have any driver side rear hub with abs sensor if so how much? cheers Paul Quote Link to comment Share on other sites More sharing options...
keron Posted June 28, 2016 Author Share Posted June 28, 2016 hi do you have any driver side rear hub with abs sensor if so how much? cheers Paul should have yes.... give me a call tomorrow or drop me a pm.... thanks Quote Link to comment Share on other sites More sharing options...
Big Supes Posted June 30, 2016 Share Posted June 30, 2016 Hi Keron, how much are V160/V161 full conversions going for these days and do you have any availability? Ta. Quote Link to comment Share on other sites More sharing options...
keron Posted July 16, 2016 Author Share Posted July 16, 2016 Just a quick note to say I'll be away from today until Tuesday 26th July... So any calls won't be answered. Please email or pm me. Thank you Quote Link to comment Share on other sites More sharing options...
S.P.R. Posted August 8, 2016 Share Posted August 8, 2016 Hi Keron, Do you have a drivers side door lock barrel and matching key or even better a full lock barrel set with matching key? Cheers, Steve Quote Link to comment Share on other sites More sharing options...
keron Posted August 8, 2016 Author Share Posted August 8, 2016 Hi Keron, Do you have a drivers side door lock barrel and matching key or even better a full lock barrel set with matching key? Cheers, Steve Hi Steve, I have a full lock set with key....give me a pm or call if needed Quote Link to comment Share on other sites More sharing options...
JOHN STEPHENSON Posted December 10, 2016 Share Posted December 10, 2016 HI KERON I eventually traced Extreme Performance as you... you cant escape! I need a mk4 1993 door lock motor for the Drivers side as the alarm engineer says it is dead. Can you help or advise? Quote Link to comment Share on other sites More sharing options...
novak Posted February 26, 2017 Share Posted February 26, 2017 HI Keron, Hope you are still around I need: Looking for complete driver side door metal trim that holds door seal - it is attached with 10+ small screws, chrome - two piece. Need to be in VGC as mine is knackered/bent. Plus both doors plastic trim screws. thanks. Hope everyone knows what I am talking about, haha. Quote Link to comment Share on other sites More sharing options...
