Glosphil Posted March 13, 2008 Share Posted March 13, 2008 I have just replaced the seals in my slave and master cylinder due to them leaking. I've put it all back together, but the fitting that connects the pipe to the master cylinder is now leaking. I've done it up as tight as I can yet it still keeps leaking between the pipe and the screw fitting. I've not managed to bur off the edges so can no longer do it up tighter or undo it. Can anyone help? Link to comment Share on other sites More sharing options...
Glosphil Posted March 14, 2008 Author Share Posted March 14, 2008 Can anyone help? car is now useless and im at an impass Link to comment Share on other sites More sharing options...
merckx Posted March 14, 2008 Share Posted March 14, 2008 I've not managed to bur off the edges so can no longer do it up tighter or undo it. I don't understand this bit. Link to comment Share on other sites More sharing options...
simbasupra Posted March 14, 2008 Share Posted March 14, 2008 sounds like the pipe is possibly cross threaded in the master cylinder? Link to comment Share on other sites More sharing options...
Glosphil Posted March 14, 2008 Author Share Posted March 14, 2008 Its ok, I've ordered a whole new pipe system from Steve Manley, should be delivered tomorrow. I've since found out I should of used a brake line spanner, but used a normal spanner and burred all the edges off.. ho hum, you learn as you work I supposed. Link to comment Share on other sites More sharing options...
Glosphil Posted March 14, 2008 Author Share Posted March 14, 2008 I don't understand this bit. haha, meant I have managed to burr them off. Link to comment Share on other sites More sharing options...
