Upgrading
c8sup
Hi all, if you had a virtually stock TT and had £2000 to spend what would the first few things you would buy????? :search:
I have been searching for weeks and there is SO MUCH stuff i cant make my mind up
Please make a list if you like, would be very helpful.
On a car of this age I would:
1. Full service, fluids, plugs, filters, O2 sensor
2. Get car on a ramp and check out the condition of the suspension, replace components as needed.
3. Fit the larger spec 4pot/2pot Supra brakes if it is fitted with the smaller spec 2pot/1pot ones. Plus braided lines, good set of pads and fluid.
4. Quality set of tyres and full geometry check.
5. Check condition of the intercooler, replace if needed.
Once car is in tip top mechanical condition then go BPU
Spot on there Nic :) (except I would swap no.2 and no.4 in the order, and add the geometry check as a seperate item after the suspension is checked out)
Get the car fullty sorted out, then think about upgrading. Believe me it costs a significant amount if you get things in the wrong order!
Thats sounds good mate, thanks for the advise, will take on board.
Yes not really a fixed list, the order of priority would really depend on condition on the car, tyres fitted, brakes fitted, etc.
My priority though would be to make sure the car is mechanically sound before even thinking about any 'upgrades'
Going to leave the car into AFR for a mechanical service. Then i will def go BPU (gaz1 told me how fun BPU was) .
The car came with TEIN Street damper fully adjustable suspension, HKS Drager exhaust & induction kit, so i think a FMIC would be the next thing.
Thank god i found out about this website, good to get feedback:)
