suped' supra
Twin Turbo 95
i just want to know what you guys think about my plans with the supra. im creating a everyday road car but something i can really take to the strip and drive the shboogie out of it and at dyno days show up and still wow the crowd.
pistons - wisco
rods - eagle
ARP rod bolts(still searching for main billits and want to replace those billits's bolts with head studs)
1000cc injectors(750cc just feels more suited, doesn't it?)
dictator engine management
stage 1 boost cooler
HKS super sequential dumpvale
turbonetics wastegate
T88 BB turbo
exhaust and intakes are made by yours truly.
and just a 50hp shot of NOS for those days that i just want to go a bit faster
268 intake cams
278 exhaust cams
wasted spark
keeping diff, clutch, propshaft and drive shaft stock.
good brakes. dont know the name. when i phoned them the phone only rang... and i phoned 4 times. stupid place! the brakes are race tested and road tested. withstands 900 degrees and picks up 80% less dust.
still searching for strong valves and im thinking about dubble springs for the valves...
if anything sounds too big or to small. just let me know. or if you have a tip. please share!
  • Replies 68
my thoughts would be that you will hate driving that on the roads every day. You will get bored of the massive lag and end up being frustrated with the fact that you have to work damn hard to over take things on single carrage ways.
ah ok. so the turbo is a bit too bit. need to upgrade the clutch... what about the diff and shafts?
i'm aiming for about 900hp. low boost 1 bar and hight boost 2.4 bar
the cams will be Tomei pieces high lift cams
And you want to use that on the road everyday :blink:
the T67 is good around 700-750... im happy with that. as long as its a damn strong car. would like 900. but 700-800 would work great... better in the streets too
How has a T67 all of sudden been able to produce 800hp.
The most we have seen here is approx 600-650hp :search:
what do you guys think about sequential turbo's?? wouldnt it work better? less lag atleast?
Let me just clear something up, have you done any research?
Did you wake up one morning and think I want a 900hp supra without looking into it :search:
