Pig Posted March 8, 2008 Share Posted March 8, 2008 Im struggling, been fitting some silly lights etc for Dragonball but at the moment i have the wires hidden but going round the edge of the A pillar and inside there as i couldnt get the wire through with the engine wiring loom. Is there a special trick. Tried searching but cant work search very well. Link to comment Share on other sites More sharing options...
Jake Posted March 8, 2008 Share Posted March 8, 2008 Through the rubber clutch pedal grommit is the usual favourite. Link to comment Share on other sites More sharing options...
kieren1234 Posted March 8, 2008 Share Posted March 8, 2008 Any wires that i have plumbed into the engine bay, i have gone through thewiring loom rubber at the far right of the engine bay. Link to comment Share on other sites More sharing options...
Pig Posted March 8, 2008 Author Share Posted March 8, 2008 Through the rubber clutch pedal grommit is the usual favourite. Will go and look for that - will i still have that as i now have a clutch pedal? Any wires that i have plumbed into the engine bay, i have gone through thewiring loom rubber at the far right of the engine bay. Tried there and seen that TDI have used it but im dammed if i could get wire to come out the other end when i put it through. Link to comment Share on other sites More sharing options...
SupraJames Posted March 8, 2008 Share Posted March 8, 2008 Grommit behind the charcoal canister is my fave for ICE wiring, comes out in passenger footwell, above and to the left of the ECU cover. Link to comment Share on other sites More sharing options...
edge Posted March 8, 2008 Share Posted March 8, 2008 Will go and look for that - will i still have that as i now have a clutch pedal? Tried there and seen that TDI have used it but im dammed if i could get wire to come out the other end when i put it through. Its easier then you think! i run a boost pipe through there. If pushed through from the bay it should come down near the ecu in the footwell. Try and use some domestic cable (just 1 wire ie red or black) as its stiff and easier to push through and you can use this to tape your wires to and pull them through.. Where the loom comes from the bay into the bulkhead you will see the big bubber cover and you can pull that back to make it easier. Link to comment Share on other sites More sharing options...
Pig Posted March 8, 2008 Author Share Posted March 8, 2008 Its easier then you think! i run a boost pipe through there. If pushed through from the bay it should come down near the ecu in the footwell. Try and use some domestic cable (just 1 wire ie red or black) as its stiff and easier to push through and you can use this to tape your wires to and pull them through.. Where the loom comes from the bay into the bulkhead you will see the big bubber cover and you can pull that back to make it easier. Good idea, ill try that. Link to comment Share on other sites More sharing options...
G-NEMIE Posted March 8, 2008 Share Posted March 8, 2008 "Poke it with a Pointed stick" Link to comment Share on other sites More sharing options...
SupraJames Posted March 8, 2008 Share Posted March 8, 2008 Try getting 4AWG cable through that hole lol !!, my advice is use a metal coat hanger, fee it through from bay to footwell (need to remove charcoal canister) then tape the wire to the end of the coat hanger and pull it through Link to comment Share on other sites More sharing options...
Matt H Posted March 8, 2008 Share Posted March 8, 2008 Call me stupid,but there is rubber bung on the top right hand side of engine bay specifically for wiring to go through?! cant you just use that? Link to comment Share on other sites More sharing options...
Supra_dan Posted March 8, 2008 Share Posted March 8, 2008 Call me stupid,but there is rubber bung on the top right hand side of engine bay specifically for wiring to go through?! cant you just use that? Stupid! Link to comment Share on other sites More sharing options...
Burna Posted March 8, 2008 Share Posted March 8, 2008 Im struggling, been fitting some silly lights etc for Dragonball Oh really, I wonder where you got that idea from Me thinks I'll have to up my game a little Link to comment Share on other sites More sharing options...
Pig Posted March 8, 2008 Author Share Posted March 8, 2008 Oh really, I wonder where you got that idea from Me thinks I'll have to up my game a little Bring it on, you've got to up your game a fair bit......as does Mr Lover Link to comment Share on other sites More sharing options...
Burna Posted March 8, 2008 Share Posted March 8, 2008 Bring it on, you've got to up your game a fair bit......as does Mr Lover I have just thing in mind already my young padawan Link to comment Share on other sites More sharing options...
TLicense Posted March 8, 2008 Share Posted March 8, 2008 I go through the grommet's behind the inner wheel arches. Bit of a faff, but it keeps it all nice and tidy out the way. Link to comment Share on other sites More sharing options...
gaz1 Posted March 8, 2008 Share Posted March 8, 2008 tell me more about this dragonball, are you all keeping it a secret from me:sly: Link to comment Share on other sites More sharing options...
Homer Posted March 8, 2008 Share Posted March 8, 2008 There's quite a few places to get cabling through (I think all have been mentioned). There's one on the passenger side where the engine loom comes through, but this is difficult to access. There's two yellow coloured bungs on the drivers side that come through the wing. These have much more room to get cables though. Seeing as the interior and inner arches are out on mine I can take some pics if you need an idea of what to look for? Link to comment Share on other sites More sharing options...
tomgeer Posted March 8, 2008 Share Posted March 8, 2008 Whilst were on this subject what about the 4mm pipe for a boost controller, where's the best place to route that? Link to comment Share on other sites More sharing options...
patrikbrunt Posted March 8, 2008 Share Posted March 8, 2008 I got 0AWG through that grommet with no probs did have to enlarge the hole somewhat though hehe Link to comment Share on other sites More sharing options...
ivan Posted March 8, 2008 Share Posted March 8, 2008 tell me more about this dragonball, are you all keeping it a secret from me:sly: Link to comment Share on other sites More sharing options...
