How "mental" are you...
Guigsy
  • Replies 51
Your neurodiversity (Aspie) score: 92 of 200
Your neurotypical (non-autistic) score: 108 of 200
You seem to have both Aspie (neurodiversity) and neurotypical traits
Diagnostic prediction for Score Prediction
Dyslexia 128 You very likely will be able to receive the diagnosis
ADD/ADHD (Attention Deficit Disorder) 102 You will probably be able to receive the diagnosis
OCD 87 This isn't a primary diagnosis you should seek
Social phobia 77 This isn't a primary diagnosis you should seek
Asperger/HFA/PDD 76 This isn't a primary diagnosis you should seek
Bipolar 70 This isn't a primary diagnosis you should seek
I think I'm screwed.... :(
Your neurodiversity (Aspie) score: 55 of 200
Your neurotypical (non-autistic) score: 157 of 200
You are very likely neurotypical
OCD 81 You might be able to receive the diagnosis
Bipolar 45 This isn't a primary diagnosis you should seek
Social phobia 42 This isn't a primary diagnosis you should seek
ADD/ADHD (Attention Deficit Disorder) 34 This isn't a primary diagnosis you should seek
Asperger/HFA/PDD 27 This isn't a primary diagnosis you should seek
Dyslexia 19 This isn't a primary diagnosis you should seek
Thank you for filling out this questionnaire.
Your neurodiversity (Aspie) score: 102 of 200
Your neurotypical (non-autistic) score: 124 of 200
Social phobia 98 You might be able to receive the diagnosis
OCD 98 You might be able to receive the diagnosis
ADD/ADHD (Attention Deficit Disorder) 76 Your diagnosis might not be correct
Bipolar 74 It is unlikely you will be able to receive the diagnosis
Dyslexia 63 This isn't a primary diagnosis you should seek
Asperger/HFA/PDD 54 This isn't a primary diagnosis you should seek
Guess I'm nuts then :)
What's the numbers Pete?? Yours looks mid rangeish all over. Don't know what that means.... do you?
No idea. I think I'd need to look up the definitions. I'm wondering if the map/graph is shaded red and green to indicate good or bad zones?
Your neurodiversity (Aspie) score: 83 of 200
Your neurotypical (non-autistic) score: 135 of 200
Asperger/HFA/PDD 76 You might be able to receive the diagnosis
ADD/ADHD (Attention Deficit Disorder) 75 You might be able to receive the diagnosis
OCD 61 It is unlikely you will be able to receive the diagnosis
Dyslexia 29 This isn't a primary diagnosis you should seek
Social phobia 27 This isn't a primary diagnosis you should seek
Are you sure? Are you really sure? Are you really really sure? Think you'd better check, then check again and again :D
See, see, see. I don't do any of those weird things and it told me I had OCD?? Just because I ticked I like routine in my life and I don't really like unexpected visitors lol :blink:
OCD 58 It is unlikely you will be able to receive the diagnosis
Social phobia 55 It is unlikely you will be able to receive the diagnosis
Bipolar 53 It is unlikely you will be able to receive the diagnosis
ADD/ADHD (Attention Deficit Disorder) 52 It is unlikely you will be able to receive the diagnosis
Asperger/HFA/PDD 34 This isn't a primary diagnosis you should seek
Dyslexia 28 This isn't a primary diagnosis you should seek
I think I am ok :)
What's OCD?? :(
Will alcohol help? :)
Maybe lol but hasn't helped me yet and I try hard every weekend :D
I think I am ok :)
Your the only sane person here. :ban:
(Joking)
Your neurodiversity (Aspie) score: 4 of 200
Your neurotypical (non-autistic) score: 196 of 200
OCD 17 It is unlikely you will be able to receive the diagnosis
Social phobia 7 This isn't a primary diagnosis you should seek
Bipolar 1 This isn't a primary diagnosis you should seek
Dyslexia 1 This isn't a primary diagnosis you should seek
ADD/ADHD (Attention Deficit Disorder) 1 This isn't a primary diagnosis you should seek
Asperger/HFA/PDD 0 This isn't a primary diagnosis you should seek
It should say that I'm extra sad doing stupid questionairs !
What does mine mean..?
Your neurodiversity (Aspie) score: 70 of 200
Your neurotypical (non-autistic) score: 159 of 200
OCD 94 You might be able to receive the diagnosis
ADD/ADHD (Attention Deficit Disorder) 85 You might be able to receive the diagnosis
Bipolar 42 This isn't a primary diagnosis you should seek
Dyslexia 42 This isn't a primary diagnosis you should seek
Asperger/HFA/PDD 41 This isn't a primary diagnosis you should seek
Social phobia 33 This isn't a primary diagnosis you should seek
