Ecu light
Marco79
Just been out for a country lane ride and the ecu light came on but the car carried on running as normal. When i turned the ignition off then restarted the car the light was gone. Is there a self correction on the soops if a sensor drops out of sync or could this be a new intermittent fault somewhere? :search:
the engine managment light on the top right of the dash also brings on the handbrake light in middle of the rev counter. Not checked the codes will look into that
Thats not the handbrake light. ;) Thats the warning triangle. You will notice it comes on if you open the doors too with ignition on.
